R55 Baby Kito's Clubbie timeline
#51
November Update
The car is getting quite few new LED's for the interior and license plate. Also found a nice hole in my A/c line in my passenger side wheel well area. I took a video and will post that along with an exhaust video tonight. I'm looking for ideas on how to work around that pipe. It got destroyed via my axle while driving so low so Ill need to come up with an alternative to it. Any ideas are greatly appreciated. Also if anyone can tell me how to recharge an A/C system that would be very helpful. I've never done it before so sorry for the dumb question. Pics to follow!
#52
November Update
#54
#58
#59
dudeee lookin' forward for that big snail/tune =D
#61
#62
Btw, I just purchased a JCW Shift boot.......
#64
#65
Thanks man! sounds good! yeah i wanna figure out how much i need to fit my new NUE! hehehe ;]
#68
#70
Update! I installed my Franken Turbo TIP and JCW shift boot along with all my interior LEDS. The car is coming along quite nicely. The turbo should be installed come last week of December into The first week of January.
Attachment 68213
Attachment 68214
Attachment 68215
Attachment 68213
Attachment 68214
Attachment 68215
#71
Actually i took the line that originally went from the valve cover to the TIP and snipped it and ran a line to the can and then from the can back to the TIP. It looks confusing because of the way the TIP is designed in this photo. I just contacted FT and they are making a new TIP with a lower side port for OCC applications. Ill have that come next week and will show better pictures. NAM app does no justice.
#72
MINI got a feature on an online site Show Stoppers. Check it out guys and let me know what you think!
Show Stoppers
Show Stoppers
#73
November Update
If you need a custom line, you'll have to discharge the system (technically illegal to do so have a shop recover it to stay compliant), remove your hose and take it to a hydraulic shop. Tell them to cut out the metal section and replace it with barrier tubing in your choice of length.
System refill is a little more involved. You need a compressed air driven vacuum pump to evacuate the system and refill with new refrigerant. (or have a shop do it)
#74
You can get e refrigerant license online for around $35 (just take and pass the test). If you're just charging, buy the refrigerant and hose kit and go.
#75
Well I'm assuming the system has nothing left in it since my line is more than just a small leak. Hole is the size of a nickel. I might just take off the hose and get it custom made up to fit over the axle, then re install and take it somewhere to have it recharged etc.
They'll also change out your AC drier. It's not a scam to sell you more parts, you have to swap it to replace the dessicant every time you open the AC system.
