R55 spongy brake padal
Old Feb 3, 2012 | 08:43 AM
NYMINI's Avatar
NYMINI
spongy brake padal
does anybody knows why the brake pedal feels spongy after I changed the front brake pads on my 2008 miniclubman s? I replace with semi metalic premium pads. Also I tried to reset the computer and the number of miles left (3600) to change the front brakes does not change. the computer resets but the miles to go does not change.
Old Feb 3, 2012 | 09:18 AM
Braminator's Avatar
Braminator
You now need to bleed the system for the pedal to return to the right feel.
You need to bleed in this order: rr-lr-rf-lf
Try this and see if it works out for you.
Old Feb 3, 2012 | 09:51 AM
proximo's Avatar
proximo
The only time I had spongy brakes was when I left off the cap for the brake fluid and when I disconnected the vacuum hose on the engine and forgot to reconnect it.
Of course, sometimes it's just you need to pump the brakes a few times before departing to get the system re-pressurized if you removed the fluid cap and pushed the calipers all the way back.
Old Feb 3, 2012 | 09:55 AM
NYMINI's Avatar
NYMINI
Thanks, will do that
Any idea why the comp. After resetting, the number do not change
Old Feb 3, 2012 | 01:53 PM
walk0080's Avatar
walk0080
Did you replace the brake wear sensors? There are two of them... 1 on front, 1 on rear.
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
