I have looked at the job, And I did replace the thermostat, but it obviously has to come back out, just cant figure how to get the plastic tube out Ugh?
Can check out this thread here for some useful tips while you go at the job. Some people just remove the thermostat. Good luck.
Ahhhh Haaaa!!!! That's exactly how my thermostat came out. With the ends missing, I actually found one piece in the block, Ugh, Thanks for the heads up Mate! I'm on it!
thanks @systemlord yeah took off the thermostat off the get to the pipe n indeed was broken. ... I got the new one but now i want to take down the water pump again to make sure i get that rest of the water pipe out. Tomorrow i guess.
New n old
N thanks too @ecstunning figure they would be sandwiched inbetween
Did that thermostat recently at 56k miles. Also, the valve cover is wet of oil on top but not dripping anywhere. Installing the N18 mod to block the passenger side PCV and installing the BSH catch can kit on the drivers side. It should minimize oil leaks and carbon buildup on intake.
