R55 3rd Door Won't Open
3rd Door Won't Open
The other day I went to open my 3rd door and nothing...I was a little shocked then mad.
Well after a few choice words and a smoke I found the problem. On the bottom of the 3rd door is safety switch that is designed to prevent the door handle from operating with the front door closed. I wiggled it and pushed it in/pulled it out a couple of times and it is working alright.
Good enough till the first service.
Shawn
Shawn
YEP - Had the same problem and the dealer pulled the bulletin on the subject and fixed it. Also had trouble with the driver window not doing the up/down shuffle when you open/close the door. There was a bulletin on that problem also. That one took 3 hrs to fix as they had to do some reprogramming of the control module.
Another thread with the same issuehttps://www.northamericanmotoring.co...d.php?t=138667 Cable replaced on mine, no more problems.
Dec 23, 2015 10:36 AM
caiken
Aug 30, 2015 05:34 PM
Mine does the same thing
