Can I reuse my oil?
Please read the whole thing before thinking I've gone nuts. I read a thread and several other message boards (not all were MINI boards) about people who bought brand-spanking-new cars. Quite a few used magnetic drain plugs to clean the shavings out of the engine from when the factory bored out the engine cylinder holes. I plan to install one but my car hasn't even hit 1,000 yet.
Can I filter the oil out and pour it back in without any harm after installing the new drain plug? There's no way to turn my car upside down so I can avoid spilling anything.:lol: Can I also just dry out the filter and re-install it? Remember, my car has not even hit 1,000 miles. |
Originally Posted by beasleyboy
(Post 2547023)
Up to you but no, I wouldn't do it. Especially the filter. Once out it stays out. Filters are cheap compared to the price of an engine. I would wait and install the drain plug with the first oil change. First change I did was at 2600 miles and had to force myself to wait that long as it seems the general consensus is to keep the break in oil in there a while. Changed my oil yesterday for the second time with 9K on the clock.
Just my thoughts on the subject for whatever it's worth... |
No.
warranty = void
No. Magnetic drain plugs and oil filters still don't catch everything. Change it all....and change it while the oil is still warm. Oil has suspension properties in it and changing it while its warm helps get the rest of the shavings and other stuff out of the motor.
:no:
An oil change, if you do it yourself, should cost you less than $30 including the filter. CHEAP insurance if you ask me.
and BTW: even if you did reuse the oil (which I still recommend against) why would you be removing the oil filter? Every oil filter comes with a new rubber "O" ring which leads me to think it isn't wise to try to reuse one. Again, I recommend against the whole idea but recommend in strongest terms against removing and reinstalling the same filter.
If I read it right he's looking to add a magnetic drain plug now and wants to just reuse the original oil that's in it now. If that's the case, I would think it would be fine. Especially since the car only had about 1000 miles. I just wouldn't reuse oil with any more miles than that.
Actually, after thinking about this a bit, I remember an episode of the Red Green Show where Red Green did this exact same thing. It seems like an okay thing to do as long as you do it the same way he did it:
Originally Posted by on2wheels
(Post 2547054)
(Post 2547054)
Originally Posted by tim781996
(Post 2547250)
Beasley, spring for new oil. :nod: |
Please, your car does not have 'break in' oil. It does not have to changed early (but, you are free to do so if you wish). Remember that you need synthetic oil. The oil in your car is std Castrol synthetic oil (according to the sticker in ours). You can safely leave it in there for quite a long time.
NEVER reuse an oil filter. Once it is off, throw it away. IMHO, magnetic drain plugs are useless. Oil filters are there for a purpose and they work. Yeah, you might see some metal shavings on a drain plug. If you want to see even more take apart an oil filter. And, don't forget too that any aluminum bits (or bearing material) won't be attracted to it :) Oil change intervals are up to you. I don't plan on doing one for a long time, at least 10k mi. charlie |
Amen Porta.
Relax & drive. |
