R55 Clubman Quirks
This is something I believe with all MINIs with the iPod interface and maybe I haven't figured it out.... But if I want to listen to a song by Yes I have to scroll through several hundred artists (if I go through the genre or artist list) to get to the band. I know if I had a few artists it would be easier, but I wish MINI had a better way to move about the music on my iPod. I have come up with a work around but it is a pain.
Also, the connection between the MINI and the iPod doesn't keep the iPods battery charged all of the time. I have to remove my iPod and charge it overnight. It's not a biggie and I don't have a problem doing it but I was hoping it was like what a friend has in his A3. He's never removed his iPod and it stays charged.
What model of iPod do you have. There is a model/serial number on the back. I would need that info not just the gen4 or gen 5 info.
Some iPods are designed to work with fire wire ports as well as the USB and it seems those may be a problem.
As long as you have the USB adapter it should keep the iPod charged . Mine has been in my car for over two months now with out running the battery down.
The actual requirement from Apple is a "Full Power" USB port and the Mini has a Limited Power USB port but even on that the iPod should charge unless there is something wrong with the usb port.
As for the charging issue you may want to think about having the battery replace. Old batteries can take a lot more current to charge than a new battery.
If you can get your hands on a newer iPod and test that to see if it discharges the battery. If it does it mean a service call to your dealer to get it fixed. If it does work (does not discharge) try getting the battery changed in your older iPod.
One thing I wish they change for future owners is the amount of resistance the door exhibits at each natural stopping point. For instance, if I park on an incline and open the door fully, the door will not stay at the open position. It’ll come slamming back down. This also happens during heavy winds. I’ve been slammed in the back on more than one occasion because of this. Anyone else experience this?
It's quite annoying.....Donna
Mine, too, with the punch carbon leather seat!
I'll agree... MINI could make the detents in the door holders a bit deeper so that, when the door swings out, it would catch and hold a bit more firmly.
You will get more experienced in how hard to 'throw' the door out to catch the notch you are looking for, but it definately isn't as 'grabby' as I'd like it to be.... Hmmm... maybe another mod coming! :D
I agree about all of these... but I love the car! The door stops don't even work in my flat driveway! So, I just ordered the fresnel lens, perfect. Wish I'd thought of that. My best solution to now was looking out the side window toward the stoplight.
Question Please: Someone posted a web site where we could buy a $20-ish device that guides the seatbelt alongside the head restraint. It fits through the two posts and then takes the belt in a slot. I lost the link and now that I've ordered my lens, I want to fix the reach around problem too. Sliding the little tab up hasn't quite done it for me. Does anyone know where that accessory company is? Thanks. BTW, 8000 miles and zero issues with my HC MINI.
Does anyone else find the throttle pedal too easy to push down? This is definitely not a Clubman thing, it's a recent (last few years) BMW thing. On my 1996 328i and my wife's 1998 740iL and all the previous BMW's we've had, this was not an issue. On my 2003 330Ci and both of our Mini's the pedal just seems real limp....
Best of luck if you decide to try that route.
but there should be a switch/wire in or from the belt buckle that is used to inform the system that the belt is in use. It will take some investigation and maybe technical/electronic ability to locate the wire and then one can 'disconnect' that part of the circuit.
WDS Wiring Diagram System Checking the components of the multiple restraint system
Caution: Do not test components of the safety system with multimeters or other universal test devices.
Testing with a multimeter or other universal test tools can lead to accidental deployment and injuries. For system diagnosis, use only the BMW diagnosis system.
Caution: Do not connect any electrical test devices to the wire harness of the multiple restraint system.
Do not connect any electrical test devices to the wire harness of the multiple restraint system as long as the wire harness is connected to a component of the safety system. Accidental deployment and violation can occur.
Use exclusively the BMW diagnosis system for system diagnosis.
Also note that there are six (6) systems that all interact with each other to form the restraint system and if anyone of them is fiddled with then i can cause the others not to function properly
The four systems are
1. Seat belts and connection sensor supposedly for all four seat locations.
2. Seat occupied sensor - this sensor is weight sensitive. for
3. Seat belt tensioner
4. Air Bags.
5. Air Bag Deactivation switch for passenger seat
6. Crash Sensors (accelerameters) 6 of them
All of these connect to the MRS (multi restraint system) controller. The controller then decides what to do in the event of an accident.
Such as if there is a frontal crash the acceleration switches let the MRS know that a front crash has been detected and depending on the severity of the crash will do one of three things.
1. Trigger seat belt tensioners only
2. Trigger seat belt tensioners and air bags.
3. Trigger seat belt tensioners and air bags and turn off fuel pump.
These systems are so integrated into with each other that it is dangerous to mess with any of them in such a manner as to short or disconnect any one. It could stop any part or all parts from working correctly.
ipod problems
I've had ipod problems since I got my car in beginning of August. I have the a 5th generation ipod 30gig that was the first of the new 5G ipods with video. I have the convience package with the USB/ipod adaptor. My ipod only registeres on AUX and not on USB. My wifes Nano howerver works fine. I had the sales manager try his iphone and had the same problem as I did in my car. It seems to be random, but now it is becoming a PITA, since the sound quality is terrible and the ipod does not charge.
ipod problems
I have had ipod problems since I got my car in the beginning of August. I have the a 5th generation ipod 30gig that was the first of the new 5G ipods with video. I have the convience package with the USB/ipod adaptor. My ipod only registeres on AUX and not on USB. My wifes Nano however works fine. I had the sales manager try his iphone and he had the same problem as I did with the device just picking up on the AUX port. He switched out the USB cable to see if it was faulty, but we still had no luck. It seems to be random, but now it is becoming a PITA, since the sound quality is terrible and the ipod does not charge.
I'll need to bring it into the dealership, but I'll be surprised if they can fix the issue. My guess is they'll tell me my ipod is the problem.
Right here: http://www.lightinsight.com/ I've had the same one since I bought my first MINI.
