R52 Convertible top hydraulic pump valve
Hi! I’m in the final stages of repairing the top (replaced rear quarter panel window regulator and left latch) and have a question about the ****-off valve for the pump. I jumped the gun and unscrewed it without counting 1.5 turns. Is the screw supposed to be fully tightened?
TIA!
TIA!
From my understanding, you unscrew the little hex screw 1.5 times if you have an issue with your top not working and you have to put it up manually with a helper. The opening of the screw provides the fluid to transfer to the other reservoir in the pump slowly wnem moving the top into position without the top motor running
Bryan
Bryan
03-20-2018 08:08 AM
PelicanParts.com
04-20-2017 09:32 AM
DustinDallas
65
03-20-2005 07:14 PM
