Thank you guys for the tips. Definetely will be looking into the wiring since I had the control arms bushings replaced and the mechanic who did it is not Mini specific. Is so annoying to have the dash looking like a xmas tree!
Need to get the MINI diagnostic software and read the computers out as the 700 fault is a very generic fault and doesn't give you any real info.
Which software would you reccomend? I have a little ELM327 Bluetooth Ebay adapter plugged in and I read the codes through the Torque app right now. I've been able to clear other codes before, but these ones keeps popping up right away, so I know the fault is a real one.
So yeah, I think I found the P1777 code... disconnected ABS sensor at the front right wheel. Plugged it in, cleared de codes with Torque and didn't pop up again.
The P0700 persists though, I wonder if they forgot to plug in something else. Where is the transmission control module located? (automatic agitronic trans)
UPDATE: Everything looks plugged in, but I'm having the dreaded 3-4 flare, with 65k miles on the odometer . Maybe that's the reason P0700 popped up. I'm reading this thread now: https://www.northamericanmotoring.co...ed-at-80k.html Hope I can find some answers there!
