Suspension Question
I recently purchased an '06 R52 S and just completed a 3,500 mile road trip. It now has just short of 130k miles. My question is this..do all Mini's ride this hard? I felt every bump and hear every rattle. I suspect that the struts are original so should I replace them? I've already been told that the towers are fine. On a side note, is it a common problem for things to come loose and rattle significantly? I am mainly concerned about the center dash area where the climate control and radio are located. How do I check to see if those things need to be tightened up?
First off, you got yourself THE very best model of them all hands down. Now,did you acquire it from a dealer, individual or used car lot? Did you get any kind of service history and/or PPI?
If this is your first 'sports' car of any kind you may notice a strong difference in the ride compared to Detroit or far East iron. The very short wheel base has a lot to do with it. You will discover that these little guys hate gravel roads with a vengence. If you can locate thru a local car club or help from the forum locating a reliable BMW/MINI independent shop nearby, you will want to have them give it a thorough looking over. There well could be worn suspension bits that do need replaced, especially the strut tower bushings. Getting into the dash board is pretty messy. There are old step by step demos way beck in the Gen 1 archives. Did anyone point out fuel requirments? You must use Top Tier 91 or higher fuel. The outcome of not doing so can cost $. Saving a few pennies on fuel will cost that out later. Ours has numerous long distance road trips and has a few rattles of it's own. They're mostly heard with the top up but who drives around like that? |
Welcome! A 3,500 road trip sounds like a fun way to break in your new car.:thumbsup:
If the suspension is original at 130K then it's probably shot, especially the front control arm bushings. One of the main sources of a harsh ride are runflat tires. Does the car still have runflats? Also, what size tires are on the car? MINI's are known to become full of rattles and being a vert might make it worse. You say the strut towers are still good so if you don't already have strut tower defenders, add some to make sure they stay that way. If you replace the struts, and don't want performance struts, Koni FSD's or whatever they're called now are supposed to ride and handle better than stock. Just make sure your car doesn't have lowering springs if you go with FSD's. |
At just over 50k my struts were toast. I have seen numerous posts here over the years from Vendors saying the you should replace at 50k and I always thought that was BS. Nope, it was not. So if by some chance you have the original suspension on your car a Mack Truck would probably feel like a Cadillac to you.
On rattles, a Gen1 MINI has more shakes, rattles and rolls then Fats Domino had thrills on Blueberry hill and a Vert has even more, A big source of rattles are the trim tubes that go from the center console up on both sides of the radio. The bottoms are like a bugle whereas they are curled out so that you cannot pull them up through the console holes but rather have to pull them down. If you wrap some masking tape around the horn part you may have less rattles. The curled portions are only about 1/4" below what you see when they are installed/tightened down so you do not have to put allot of tape on them. |
Originally Posted by Fly'n Brick
(Post 4405230)
Originally Posted by RB-MINI
(Post 4405236)
Originally Posted by Whine not Walnuts
(Post 4405240)
The struts and springs come apart so you can just replace the struts and maybe the top mounts if the rubber is cracked. It can be dangerous if you don’t have the correct tools so have a shop do the actual spring removal and re-assembly if you’re not familiar with the procedure. The R&R of the whole strut isn’t too hard if you’re handy with tools, it’s just the R&R of the springs from the struts you have to worry about.
They are pretty stiff, but with 130k you likely do need struts. We find the Koni FSDs ride the best
https://www.waymotorworks.com/koni-fsd-shocks.html Also if the car has runflat tires go to regular tires and you will be much happier. |
Echo on the Koni FSD, big ride improvement. My struts were toast by 60k miles.
Make sure your mechanic changed the Lower control arm bushings, these are critical to decent ride quality and wear out fast if OEM. If you have not changed them put in poly bushings and change the sway bar bushings at the same time. 16" non-run flat tires ride a little nicer due to more sidewall. Lube all the mechanics in the top. Lube all the rubber moldings with Gummifluge. The A-pillar inside trim needs to be set in its proper position from time to time to stop it from buzzing. |
