Question with my piston
After being cleaned!
The pin that goes through, it’s sort of stuck with the connecting rod! Is that normal?
I thought the piston should ride smoothly on that pin but it seems that the rod is moving along with the pin.I did a search and it seems that in order to remove it? It needs to be heat it? I don’t have a press to remove it.
I’ve seen videos when people repack it they would used assembly grease but if heats needs to be apply to install it would be melted!
how loose the piston needs to ride on the pin or spins with it as one piece?
right now the connecting rod spins with that pin as of one piece!
i hope you understand what I’m trying to say😳
I've got Mahle Motorsport replacements for the Cooper . Better pin and much better piston strength than the stock cast ones. They also come with some killer rings. Let me know if you need them
I have a sale on them.
http://store-revolutionmini-com.3dcartstores.com
gum (05-23-2018)
There are a few methods in which the piston, wrist pin, and con rod are secured together. Some older motors utilize a circlip on each end of the wrist pin to keep it in place. I infer newer motor design tend to rely on interference fit between the wrist pin and the small end of the con rod. From the photo the Mini must fall into the latter. Obviously you will need a good hydraulic press to press out the pin. By this I exclude the bench top toy press HF sells.
May be the retired tool and die maker with extensive heat treating experience can chime in.
I saw in YouTube that I would need a torch to hit the rod by the wrist pin then extract it. or taken it to a machine shop; but my worry is that the rod is sort of stuck on the wrist pin and when it swivel as one unit together the rod and wrist pin so, it’s spinning on the skirt of the piston.
may be there is a builded up of dirty stuff in there, the piston are good it’s a shame replacing them, I would look for a cheaper alternative which is cleaning them and lube them and see if I could get them move as they should.
If I have not mistaken on the Mini con rod. Interference fit means they are practically fused together as one, as intended by the design. Hence the wrist pin only swivels about the piston bores. Unfortunately when it comes to this kind of work, Bentley manual is less useful than a roll of toilet paper.
gum (05-23-2018)
I’m getting ready to do some pistons(walls) honing since I have the pistons out on cyl 1&4 then I would do 2&3 cyl, I m doing it while the engine is mounted.
thinking ahead to break the engine I’ve read that I should no used synthetic oil? Is it right to do this?
The reasons being that it would prevent the rings to properly fitting with its cylinder walls!
Clutch Wotan
03-08-2021 06:40 PM
Drivetrain HELP -- rear brake piston does not retract!
Exbat
10-21-2003 05:31 PM
Drivetrain 4 piston fixed caliper for the rear rotors
m3jstock
06-21-2003 09:03 PM
