North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R52 :: Cabrio Talk (2005-2008) (https://www.northamericanmotoring.com/forums/r52-cabrio-talk-2005-2008-152/)
-   -   R52 AC and rear defroster doesn't work (https://www.northamericanmotoring.com/forums/r52-cabrio-talk-2005-2008/295150-ac-and-rear-defroster-doesnt-work.html)
minileprechaun Oct 30, 2015 07:36 AM
Is power to the AC and rear window defroster lines connected together?
Neither work. Plus, the little lights on the buttons don't turn on when you push the buttons.
I'm more concerned about the rear defroster.
I've looked at the defroster fuse in the driver's foot well fuse box and it's still intact.
Another weird situation. I went to for a long drive, had the air on, and hit the AC button to test it out. AC light did not turn on, nor did ice cold air escape the vents. However, after I parked, I noticed the condensate dripping from the car, so something about the AC is working.
and one more, on a brisk day, I drove and wanted to just use the fan to pull in outside air. But the air was much warmer than the outside world. Is this normal? is there a way to draw in the cold outside air?
So I'm confused about what is failing here!
ECSTuning Oct 30, 2015 02:01 PM
Hello,
Have you spilled and drink or soda on the climate control unit face ? Possible it sticking or the fluid has damaged it.
Did you check the fuses under the engine bay on the driver side also ?
For the rear defrost also make sure the cable is connected to element on the side of the window , on a convertible when you put the top up and down those cable can pop off.
minileprechaun Oct 30, 2015 04:28 PM
Originally Posted by ECSTuning (Post 4139587)
Hello,
Ah. Thanks for all those tips!!
The car is used, so I'm not sure about drink history. I'll pop off that plate eventually and look behind the controls to see what I can find.
The knobs that control fan speed and distribution work correctly.
I tried looking at the fuses under the hood but couldn't make much of them. I'll have to check that again.
I'll also check the wire at the defroster window. Wouldn't it be great if it was that simple!
ECSTuning Nov 2, 2015 06:01 AM
You are welcome, as a owner of multiple MINIs I know about these things :wink:
Let me know if you need anything else.
Nate Ballog May 9, 2020 05:45 PM
Has anyone figured this situation out? Same situation with an 04
Nate Ballog May 9, 2020 05:47 PM
same problem on my 04. no ac no rear defog no lights.
Anyone figure this out?
tjperry91 Jan 13, 2023 06:21 AM
did you ever find this problem and solve it ? I have a random wire hanging
3 pin
black yellow and transparent
ECSTuning Jan 13, 2023 12:21 PM
Their is one wire that runs and connects to the defrost element. It has a tab connection. Post up your pics.
jiggersplat Jun 19, 2023 09:14 AM
bump. anyone figure this out?
