North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R52 :: Cabrio Talk (2005-2008) (https://www.northamericanmotoring.com/forums/r52-cabrio-talk-2005-2008-152/)
-   -   R52 Windows don't go up. (https://www.northamericanmotoring.com/forums/r52-cabrio-talk-2005-2008/252314-windows-dont-go-up.html)
rdangond Jun 5, 2013 07:06 AM
Hi, when I take the top down of my 2006 mini cooper s convertible, the windows are not going back up (front or back) automatically. Can anyone help me with this problem? I have to do it manually (by pressing the window switches).
ECSTuning Jun 6, 2013 01:20 PM
Did you hold the button all the way till the top goes down , then still hold it for a period after that? Sometimes if you lift your finger off the button a bit it will stop.
Braminator Jun 6, 2013 01:40 PM
You can try this:
Instructions
  • 1 Insert the keys and turn on the ignition. It does not matter whether you start it or not.
  • 2 Put the window all the way up (if you are able).
  • 3 Press and hold the window switch in the up position for 10 or more seconds. Do this with the door closed.
  • 4 Open the door to make sure the window drops as it should. Close the door to make sure it goes back up again.
