R50/53 My antenna broke
Old Nov 29, 2007 | 11:30 AM
  #26
cpayne's Avatar
cpayne
Same thing just happened to me this AM..grrrr!!!
Believe Part# 65206985714 for $47.04 from the dealer is what I need (2005 no Nav)
Old Dec 5, 2007 | 07:58 AM
  #27
eric loe's Avatar
eric loe
Same case happened to me. My OEM antenna base broke when I took the car to a car wash. I am thinking of replacing the OEM base with the Shark fin cover offered from Mossmini since it is cheaper than a new OEM base. Have anyone use it before? How does it looks?
Old Dec 5, 2007 | 12:50 PM
  #28
MaxMini81's Avatar
MaxMini81
Wanderer
Snapped Antenna Mast
Before I purchased my MCS, the antenna was snapped off of the base. I obviously didn't realize this at the time or I would have dealt with it then and there. The threaded section of the old antenna is still in the base. Before my warranty ran out, I watched the staff of Mini of St. Louis spend a good hour trying to get the original threaded component out of the base to no avail. They told me that its a crap shoot. Sometimes they come out, and sometimes they don't. What I do know however, is that they did put a concerted effort into it, and that the next logical step would be to replace the unit for, what i believed was quoted to be, $435.00. Originally I was going to get XM or Sirius and wrote it all off. Now though, I've reconsidered satellite radio, and I really just want the antenna to be functional if for no other reason than to get a custom antenna for it. Do I have options? is there something out there I might have missed? The Shark Fin through Moss is just a cover right? And $435 included labor but that wouldn't take more than an hour so even at $110/hour shop fees it's still like $325. Let me know if you all have any thoughts. Thanks.
Old Dec 5, 2007 | 12:59 PM
  #29
eric loe's Avatar
eric loe
$435 to fix the antenna thats way to much. The OEM antenna can be replaced, it is bolted to the roof I believe. You have to remove it from the inside.
I have rechecked with the Moss Mini and turns out the shark fin cover is for 02-04 mini which has smaller antenna base than 05-06. So the only option I have is OEM Mini Base in which I am still waiting for a quote from my local mini dealer.
Old Dec 5, 2007 | 02:36 PM
  #30
sandtoast500's Avatar
sandtoast500
do not pay the dealer to do this. Please read this whole thread.
Old Dec 5, 2007 | 04:25 PM
  #31
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I have several of the 02-04 antenna bases in stock for $38 each if anyone needs one. I've seen this alot from people going through car washes.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 5, 2007 | 07:06 PM
  #32
eric loe's Avatar
eric loe
do you have 05-06 antenna base. If you have how much it is
Old Dec 5, 2007 | 07:27 PM
  #33
MaxMini81's Avatar
MaxMini81
Wanderer
Is the base all I need to put in a new antenna? hows the install done? I assume the headliner has to come out? Any info? Lemme know please.
Old Dec 5, 2007 | 08:46 PM
  #34
Vendor
Actually how I do it is I pop the headliner down at the back of the car. The cover on the roof actually popes off and you use a 19mm wrench to take the nut off. Then the whole antenna base will come loose and you can disconnect the wires and pull it out. Then reverse for install. Sometimes you have to reglue the clips to the headliner, but no big thing. So all you'll really need is the base and a new antenna.
I'll check and see if I have any 05-06 bases, if not I'll get you a price on a new one.
Old Nov 16, 2009 | 09:20 PM
  #35
eric loe's Avatar
eric loe
Sorry for not responding for a while but I still couldnt find the right antenna base part for my 06 cooper s with nav. Does anybody in this forum knows.
I found it here,
http://www.allminiparts.com/showAsse...sembly=i_f_265
There is one cost 145 and the other 44. I dont know which one should i get
Old Mar 16, 2010 | 12:29 PM
  #36
Speedwing's Avatar
Speedwing
The snow was 2 feet deep on top of the MINI and I was pushing it off with the new Sno Brum http://www.amazon.com/Sno-Brum-Origi.../dp/B0007LDXLA and I forgot the stubby antenna was there and SNAP .... it broke the oval housing right below the antenna. I managed to tape it up until today so no water got in....but the antenna was always a little cocked to one side!!
Part# 65206985714 for $66.04 + tax from the dealer (Otto's MINI .... who are always a little high on cost .... but they had it in stock) is what I needed (R50 - 2005 with no Nav).
One plastic clip at the middle rear of the headliner and a little tugging around the corner vertical trims and I had access. The two plugs are in a plastic wire loom held in with plastic spring clips. They smallest wire unplugged easily. The bigger wire had a tab and springy clip to disconnect. I used a 7/8ths deep 6 sided socket to get the single nut off.
Some Zaino was applied to the virgin roof under the assembly .... and the new one went in very easily in reverse order.
R & R was pretty easy overall.
I hope I do not have to pay the $70 STUPID TAX again!
Bob
Old Mar 16, 2010 | 02:08 PM
  #37
eric loe's Avatar
eric loe
I found mine at allminiparts.net. but it cost 150 bucks cause mine is with nav. so i say screw it. I ll just tape it somehow, no water leak either.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Doc Pain
Mar 10, 2021 04:50 AM
MINI Stupor
Oct 1, 2015 11:36 AM
simo711
Oct 1, 2015 05:36 AM
Giants9595
Sep 29, 2015 10:49 PM
