R50/53 91 versus 93 octane?
I've never heard an authoritative answer on this question either. Is 91 octane pump gas high enough to prevent knocking under *all* circumstances, even heavy acceleration? Or is 91 just enough to prevent knocking under *most* circumstances?
I guess the best way to find out would be an OBD-II monitor that would let you monitor the voltage coming out of the knock sensor in real-time. Then, you could figure out the minimum octane required to keep the knock sensor from activating under heavy acceleration.
Scott
Scott
Your car will perform the same either way...it's tuned for 91 so just run that...if it's cheaper.
Here we don't even have 91. Some places have 92 but most have 93 as the only choice for "premium" gas.......87/89/93. So I run 93 all the time.
In my old car, an 03 Cobra, it was tuned from the factory as well to run on 91...since it's the lower octane "premium" gas out there. Since I run 93 I got a tune that bumped the timing to run on 93 and it gave me about 15RWHP actually. (Note this is on a car that had over 400rwhp to begin with).
I wouldn't surprise me if MINI only listed 91 as the requirement to keep from scaring the people who live in places where 91 is as good as it gets. If the knock sensor is still activating occasionally with 91 octane gas, then there's probably a little more power to be had by running 93 octane, if it's available.
Also, don't forget that even if our engines *are* "tuned for 91", that goes out the window for the supercharged cars when you start swapping pullies to increase boost. That increases dynamic cylinder pressure and increases the octane requirements, and it's one of the most-common modifications we make to these cars.
Scott
Hmm, must be those additives they use to make it heavier
Read http://www.quiktrip.com/gasoline/myth.asp
Riqui wrote: Also, don't forget that even if our engines *are* "tuned for 91", that goes out the window for the supercharged cars when you start swapping pullies to increase boost.
I dont know if that is true or not true but if it were true, how do you explain that JCW cars still only require 91 octane?
Depends on where you live. The only difference is that the 93 can handle a higher compression before exploding. The exploding is what causes the knocking.
The reason some places ofer 93 and others 91 has something to do with humidity and oxygen. If you live in the high country you probably have 93 if you live on the west coast you probably have 91 available.
In the end I beleive that depending where you live 93 or 92 is equivalent to 91 at other locations where 93 would be more than you need.
The mini can utilize up to 98 octane in its computer.
the engine, if the computer was not involved can utilize over 100 octane easily.
the compression of a MC is 10.6:1 right? the MCS is less but the supercharger puts it back up to that or more. thats enormous compression for a modern car. that means it loves limitless octane (well, more than we can get normally at the very least)
under 98 octane, the computer retards timing to prevent damage to the engine, aka, knocking.
so, fill er up with max octane you can find. It will perform better for long stretches, up mountains, dragging around people in the car, etc. Supposedly not a huge difference. However, the engine enjoys it and also it is more efficient per mile. More power? yes but default it does have more power, usable power.
Your car "feels" heavier with 93 octane in it????
Scott
thanks guys
i remember an article a while back regarding sunoco not making 94 anymore for cost reasons. i have a sunoco that sells 93 pretty reasonably priced, so i use it on occasion - i am in upstate new york.
there are a few places that only offer 87/89/93, but most stations include 91
lots of good answers.
If the car is not knocking, your wasting your money http://www.quiktrip.com/gasoline/myth.asp
If your car doesn't knock or ping on lower octane gasoline, paying for higher octane is a waste of your money.
What is your reference for this piece of information
Although I would like to know the reference for the 98 rating being optimal for MINI as I would think that 91 or 93 would be the max necessary for full performance.
If you can't find higher octane gas at your local pump, couldn't you just pour in some of this?
http://www.goldeagle.com/104plus/products.htm
Here goes https://www.northamericanmotoring.co...t=octane+knock
Towards the end of the thread the statement is made. Also note how 100 octane is considered fine and great to use. midgrade???? never consider it. highest you can get with best quantity of additives possible
on
our engines are NOT tuned for 91. that is the minimal level octane you should use without suffering big consequences. They actually arent tuned at all. The timing is variable depending on knock, really, that negates the whole idea of tuning as you cant adjust the timing except for adjusting that variable control software. The engine at its 10.6:1 compression enjoys upwards of 100 octane. However, the software only can use ~95 octane or ~98 octane to its fullest. 95 or 98 I say as it seems there is a discrepency about how to calculate octane in terms american vs European measures. Some say the engineering comments are written in Euro terms, others, like me, believe that the engineers already know their audience and know the different methods of gas ratings in countries and therefore, they mean 98 american octane. Who knows though. Doesnt matter as octane only goes up to 93 in the USA unless you add Cam2 racing gas for 100 octane.
Timing adjusting means that it is compensating for crappy octane gas, not using it for its best.
In the end I beleive that depending where you live 93 or 92 is equivalent to 91 at other locations where 93 would be more than you need .[Emphasis added.]
YD
However note from your own reference FAQ
If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away.
Tuls seems to think 91 octane is NOT the optimum setting.
91 is proper MARKETING octane. to say a car needs 95+ octane to get full power would be marketing suicide. car company would love to say it can use 89 or 87, that sold many crap GM cars in the 1990's. however, what the engine wants is obscured from view.
t does enjoy 95 octane and can use it. The sicience of the engine just screams that must be so. the physical engine itself can use it, all the timing has to do is not retard and it will allow for full usage of a higher octane gas
every piece of your car's manual, every speck of the car itself, every option, every MA and every dealer advice is to get you and more people to buy it.
