R50/53 diy stripes.. or $250 stripes?
Old Feb 25, 2003 | 08:58 AM
Nomonstersinme's Avatar
Nomonstersinme
im leaning towards the diy method but im afraid of not being able to do it correctly. also its relatively cold outside so if i did it myself it might not work right...
is it easy to apply the stripes? i honestly dont think its worth it to pay $250.. esp if they do a crappy job..
any thoughts? have those who've done it themselves found it easy enough to match up the two stripes?
i could just buy the stripes from mini mania right now for $59 and do it myself... does it come with instructions on how to place the stripes?
Old Feb 25, 2003 | 09:08 AM
dave's Avatar
dave
pug poo picker-upper
Custom stripes from a local sign shop cost me $30 for materials and $45 for them to install them. I would strongly recommend that route.
Old Feb 25, 2003 | 09:14 AM
Nomonstersinme
just any kind of sign shop? do they use the same material?
Old Feb 25, 2003 | 03:57 PM
Red's Avatar
Red
What about window tinters? It seems like the materials are sort of similar?
Old Feb 25, 2003 | 04:14 PM
Yucca Patrol's Avatar
Yucca Patrol
yeah, since they are just a couple bucks in adhesive vinyl, i would not pay $250 for them. sign shop is the way to go, definitely!
Although, my opinion is lessened by the fact that the first thing I did when I got home from the dealer is peel off the offending bonnet stripes that broke up the beautiful curves of the bonnet. But that is just my opinion. . .
Old Feb 25, 2003 | 04:29 PM
Mini-Matt's Avatar
Mini-Matt
If you go through a sign shop just double check the quality of material they use. Some of the stuff out there is paper thin and will only last a month or two and won't hold up to the elements very well. Avery or 3M or the two best types out there as far as material is concerned. I use a 3M Controltac which has a silver backing - something about the material they use works well with their adhesive and the cars paint.
As far as installation goes I have an install sheet I can send you which can be adapted to any set of bonnet stripes. The install should take no more than about an hour of your time. A sign shop "should" not charge more than about $50.00 for a complete installation.
Stripes should be installed when the CAR temp is above 60 degrees. Any less than this and it is hard to work with the adhesive material and you are more likely to mess things up.
Hope this helps
Matt@cooperflags.com
gar56
Nov 15, 2016 06:41 AM
unxpectederror
Oct 22, 2015 12:16 PM
Fordgt4
Oct 10, 2015 10:42 AM
M7Speed
Oct 1, 2015 07:05 AM
krohm
Sep 28, 2015 12:16 PM
