R50/53 Hot air??
Old Dec 16, 2002 | 06:50 PM
Calvin77's Avatar
Calvin77
I've noticed that when my A.C. is off, there's always a small amount of hot (ok, warm) air coming out of the air conditioning vents, as if engine heat was seeping in through the vents. Is this normal? Has anyone else noticed this? I haven't had this happen in any other car..
_________________
2003 Dark Silver MCS, White top, Lapis Blue leather, Premium and Sport.
Old Dec 16, 2002 | 08:09 PM
jwhcars's Avatar
jwhcars
If you put on the recirculate mode and have temp on cold you will get no warm air.
You can also turn temp down and leave the car use its flow thru ventilation.
This is normal on most newer cars
Old Dec 16, 2002 | 09:03 PM
richmds's Avatar
richmds
Yes I too have noticed this. Without air on and control **** set to cold. The car tends to be warmer than other cars. At times uncomfortably warm, I usually crack the windows a bit to offset the effect.
Old Dec 16, 2002 | 11:32 PM
Calvin77's Avatar
Calvin77
Thanks for the info. Looks like you both have the manual A/C, as you mention turning "*****". I have the auto climate control, and I think this might make it worse as I have no way of "physically" adjusting airflow or temperature. All I can do is turn it off and nevertheless I always get that steady stream of warm air coming in through the vents.
I wonder if anyone else with climate control is experiencing this...
Old Dec 17, 2002 | 09:01 AM
letsmotor's Avatar
letsmotor
Check this thread Hot Air
Sep 3, 2015 01:45 PM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
