R50/53 Signs pointing to a bad alternator?
Old Dec 23, 2024 | 08:21 AM
  #26
ssoliman's Avatar
ssoliman
good to hear you got it sorted
Old Dec 23, 2024 | 09:44 PM
  #27
Alkaidovich's Avatar
Alkaidovich
This most definitely sounds like it’s coming from the (new) alternator. Before I put the belt on, I checked all the pulleys for any wiggle/movement/play and they all seemed good and fine.
It’s pretty loud at idle but I drove it around the block and it virtually went away. Pulled into the garage, and after about 10-15 seconds of idle it came back, went away, came back and so on.
Is it possible the bearings are no good on this new alternator?
File Type: mov
Old Dec 24, 2024 | 05:43 AM
  #28
Here2Go's Avatar
Here2Go
NAM Community Team
One thing you might try (not sure if it will isolate) - You might try spraying some slightly soapy water on some of the pulleys while the noise is present. If it goes away - You may have narrowed it down to one pulley (or the alternator ; in your case).
My experience or guess is that the squeal, squeak/noise maybe coming from a failing idler pulley (?)...
Just a thought.
Old Dec 24, 2024 | 06:30 AM
  #29
Alkaidovich
Just a thought.
This is what I keep reading. It could either be that, the alternator, one of the pulleys or the SC. But a lot of signs and symptoms don’t seem like the SC (fingers crossed)
I am kind of hoping it’s the pulley so I don’t have to pull it all apart again for front end service again but we’ll see.
Old Dec 24, 2024 | 08:37 AM
  #30
Tombstone's Avatar
Tombstone
Just a thought.
Idler pulley in picture appears worn out , might to remove it first and see if it spins freely with no sound …
Old Dec 24, 2024 | 08:51 AM
  #31
Alkaidovich
that is the plan for today. Unfortunately nobody nearby has it in stock and ordering online won’t be here until end of week impatient I know
but it’s all seeming to look like that’s the issue thankfully that’s a quick fix.
Old Dec 24, 2024 | 09:13 AM
  #32
Tombstone's Avatar
Tombstone
O’reilly carries the factory Litens brand (made in Germany) under the Murray pulley tensioner idler pn # 2330291 for $19.99 ; this is what came on the Mini Cooper…
Old Dec 24, 2024 | 09:20 AM
  #33
Alkaidovich
yup, saw it was a “special order” item they don’t stock. But took my chances, called and it’ll be here in about 3 hours *fingers crossed*
Then cross them again that this is the last of all this trouble. I might as well have done a pulley upgrade with how many times I’ve been under there
Old Dec 24, 2024 | 09:30 AM
  #34
Tombstone's Avatar
Tombstone
Also , with the belt off check the belt tensioner pulley , mini shock absorber rubber bushing’s for wear …
Old Dec 27, 2024 | 04:47 PM
  #35
Alkaidovich
So pulled everything in the wheel well off, idler pulley is fine. Checked all the others, it’s the alternator pulled, has wobble (and it’s brand new)
guess I have to get a replacement (under warranty) and do the whole front end… again ffs
Old Dec 29, 2024 | 07:09 PM
  #36
Alkaidovich
So the bearings were shot on the alternator.
I went through FOUR(!!!) alternators at different retailers today that all failed for one reason or another. And yes I know some will say the Autozone/Oreillys are **** but they were all Denso stamped and just reman versions.
Either way, I need to get one shipped asap. I give up on getting it locally but the one ordered online bearings also failed after 3 days. Car has been sitting for over a week now.
eljay
R60/R61 Stock Problems/Issues
Feb 27, 2025 08:12 PM
krlambrych@yahoo.com
Jan 19, 2025 10:21 AM
heemskn
Dec 9, 2024 01:59 AM
prb44t
Classic Mini Talk
18
Apr 3, 2012 05:13 AM
MrCooperS
Electrical
15
Sep 19, 2010 03:14 PM
