| MrHill05 |
Aug 16, 2023 03:25 PM |
Fuel filter and pump installed won't start
I am sure this is a repetitive thread but please indulge me. My 2005 R53 had computer issues so I installed a reprogrammed DME from RPM. It worked and the car started and ran but went into limp mode when warmed up. I am less than a novice mechanic so I decided to take it to a local shop but thought I would change the fuel filter first, as the car had been sitting at the previous owner's house for 3 years. After I installed the fuel filter the Mini would not start. Not stumble, nothing. Again, it ran before I installed the new filter. I had the car towed to the shop and asked them to get it running and asked them to take out the filter and refit it as they would normally. It would not start and they insisted the pump was bad as there was no pressure at the fuel rail. I could hear the pump run when I put the key in, and I knew the pump had been replaced before the car was sitting, so I had the car towed home. I bought a certified "working" used pump from Almag for a good price, just to check their diagnosis. After installation, nothing. So, my questions are 1. anything I should look for on the filter cannister? 2. is there something about filter installation that is special? 3. is there something I should look for on pump installation? 4. how about hoses, broken or blocked? 5. any other thoughts. I am most appreciative of any and all help here. I live near Upland CA and there are no Mini shops around here that will touch the car or which I trust, but I am open to any suggestions. Thanks!
