My R53 Hyper blue mods and upgrades
Subscribe
Nov 6, 2022 | 02:15 PM
Hi been around here for long time and have had 3x Mini. My first car was Mini R53 in grey color back in 2006 and I have ever since been in love with Mini.
I bought this 2004 R53 in hyper blue back in 2014/5 and did big list of mods to the car but sold it. Ever since I sold the car I have always been after to buy it back, some weeks ago I came over AD and saw the car and I knew I had to buy it back. The car is in need for some TLC as the last owner have not taken that good care of the car.
So here is the mods I have done before:
  • 17% S/C pulley
  • Remap
  • Alta Cold Air Intake System
  • NGK Iridium Spark Plugs
  • Milltek Cat-back exhaust
  • Milltek manifolds
  • JCW strut brace
  • JCW steering wheel with alcantara/leather
  • JCW R56 brake kit
  • Sports brake lines (Goodridge Braided)
  • KW2 coilovers
  • GTT Rear Strut brace
  • GTT Lower Mid Chassis Brace
  • Powerflex all bushings
  • 18" OZ Superleggera
  • H&R Rear 2way Adjustable Sway Bar
  • Alta Rear Control Arms
  • Alta End Links
  • JCW injectors 380cc
  • GRS Intercooler
  • Full Aero JCW kit
  • Chrome Interior Trim
  • JCW Boot Handle Cover
This is what Im doing now:
  • R56 JCW Recaro seats
  • Quaife ATB LSD Differential
  • JCW side scuttles
  • Supercharger: new
  • JCW Airbox with flap removed
  • ITG airfilter
  • JCW door sills
  • KW2 springs, I have Kw2 coilovers on car, but springs have some rust on
  • Radiator Overflow Tank: Canton: Black
  • Radiator Overflow Tank Lid: 30PSI: Canton
  • Power Steering Tank: Aluminum Black: Canton
  • Coolant Hose Set Silicone: Mishimoto: Black
  • Ignition Coil: Screamin Deamon
  • Spark Plug Set: LGS DOR15LGS-T Stock Heat Range
  • Alta Air Intake Replacement Filter
  • Supercharger Pulley Alta 17%
  • Belt: Serpentine
  • Thermostat Housing: URO Metal
  • Thermostat
  • Water Pump
  • Cravenspeed Ultimate MINI Oil Dipstick
  • Alta Lightened Crank Pulley: Standard size
  • CocoMats
  • Whiteline Front Adjustable Drop Links
  • H&R Sport Sway Bar Kit front / rear
  • Clutch Kit including flywheel: LUK
  • Fan for Power Steering Pump REIN AUTOMOTIVE
  • Nissens 69701A Uprated Alloy Radiator
  • Engine Cooling Fan Assembly P/N:75647
  • Milltek Non Resonated Section (car have full Milltek system)
  • JCW steering wheel (32300416251)
  • R56 rear trailing arms
  • Rear Hub Wheel Bearing Kits Pair
  • Powerflex Rear Trailing Arm Front Bushes ROAD
  • Whiteline Rear Adjustable Drop Links
  • R56 Rear Trailing Arm Adaptors
  • New brake disc + pads + sensors
  • pioneer SPH-20DAB
  • JVC CS-J6930
  • JVC CS-J520X
Here are some pictures of the car with the mods I done before, and when the car was in good shape.
Reply 2
Nov 6, 2022 | 02:17 PM
So here is the seats I just bought, will get them very soon
Reply 2
Nov 6, 2022 | 03:14 PM
Love the color. Make sure you post up some install pics when you put the seats in! You probably know this already, but if you DIY the seat changeover, make sure you disconnect the battery before changing out the seats. Even if the car is off when you disconnect the airbag connectors, you will get an airbag warning light on the dash when you next turn the car on that will have to be reset by a stealership.
Reply 1
Nov 6, 2022 | 03:34 PM
Quote: Love the color. Make sure you post up some install pics when you put the seats in! You probably know this already, but if you DIY the seat changeover, make sure you disconnect the battery before changing out the seats. Even if the car is off when you disconnect the airbag connectors, you will get an airbag warning light on the dash when you next turn the car on that will have to be reset by a stealership.
Yeah I really need some step by step how I can do the seat change, as the connectors under the seat not the same. I got this picture from the R56 JCW Recaro seat, what should I do? My biggest problem is that there is not much shops in Norway that can fix this stuff for me
Reply 0
Nov 6, 2022 | 05:12 PM
I believe there should be a pretty recent thread in the interior modification subforum in the R50/R53 forum about transplanting R56 seats (with their different connectors) into an R53. That will probably have all of the info you need in there. So far as I know, no one who has changed out R56 seats into an R53 had someone else do the work for them... mostly it seems to be a tinkerer/DIY thing. Again, so far as I know. I would imagine a competent auto electronics place or auto upholstery place *may* be able to do this for you.
Reply 0
Nov 6, 2022 | 05:14 PM
Here it is. Seems to have everything you need in there...
https://www.northamericanmotoring.co...-and-pics.html
Reply 0
Nov 8, 2022 | 07:26 AM
I just got the seats today, put them in garage. Looks easy this guide, but only concern is when get to stage I need put R56 seat airbag wire in R53 plugs I dont know what color go where..
Also the heated seats I dont know what I should do
Reply 0
Nov 8, 2022 | 09:18 AM
Just bought OEM R112 wheels I think will run R112 as summer wheels and 18 OZ Superleggera as winter wheels
See picture, not my car found this photo online but same spec as my car. I think I will also get my car some up when they install new springs on KW2
Reply 0
Nov 8, 2022 | 09:20 AM
Just bought new JCW scuttles, not sure I will install them as they are OEM for R50 what you guys think?
Reply 0
Nov 27, 2022 | 10:51 AM
So I tried to install the JCW R56 Recaro seats, but for me important to get the heated function to work so I got upholstery shop to install the seats and wire. Now heating function works fine + airbag is connected etc
I even got them to trim the downtubes in leather looks + feels so nice. I had JCW R53 all leather steering wheel I got installed.
Got them to install Pioneer sph-20dab + all new speakers + microphone + DAB antenna.
Her you guys also see coco mats put in rear, in front now use rubber mats as its winter in Norway
some pictures
Reply 0
Nov 27, 2022 | 10:53 AM
I have also bought all JCW carbon trims for steering wheel + gear **** + brake handle I also bought JCW carbon dash very good condition. + JCW Leather dash and down tubes. So not sure what to use on car I think will start with the carbon dash
Reply 0
Nov 27, 2022 | 11:01 AM
My car have Goodridge Braided brake lines, but I run GruppeM brake lines on my Ferrari so I bought GruppeM for Mini also.
As I will get a lot stuff done like change springs in KW V2 coilovers I think its better to upgrade the front + rear shock top mounts, bought both Febi + Corteco, I think will use Febi.
Some other parts
Left & Right Tie Rod Assemblies
Loebro Drive Axle Front GAP
Front Driver Left Output Shaft Axle Shaft Assembly GKN
THERMOTEC KTT110319
New spotlight
+ cover for spotlight bought 2x sets
R90 wheels as I wrote before also bought R112
Brake Caliper Seal Kit front + back with new pistons I hear pistons on JCW R56 Brembo are composite so this will change to steel
I also bought JCW 210 ECU with all key etc
+ JCW top head that are in now to get refurbished
I will get the shop in UK to build new engine with cylinder etc
There will be a lot of work on this car
Reply 2
Nov 28, 2022 | 01:21 PM
So got the JCW carbon dash installed
Reply 1
Nov 28, 2022 | 06:19 PM
Pics of said Ferrari?
Reply 0
Dec 5, 2022 | 01:43 PM
Quote: Pics of said Ferrari?
Yeah here some pictures of my F355 GTS + my 996 C4S
Reply 5
Dec 5, 2022 | 11:11 PM
That’s a sweet looking 355! The carbon sport seats, Challenge grille, and Speedlines are great upgrades. Is it Blu Pozzi? One of my dream cars (that’s possibly obtainable) is a Giallo Modena GTB with carbon seats, Challenge grille, and white Speedlines.
The 996 C4S is another great car… nice turbo wide body, but clean without the intakes and tail. The pics threw me off for a minute as I didn’t remember them changing to a single grille from the double on the 993.
Can you compare the fun factor of the MINI with the others?
Reply 1
Dec 5, 2022 | 11:27 PM
Yeah Im very happy with the 355, I have taken the Speedlines off now and running stock wheels (car are in winter storage now). Yeah its Blu Pozzi and cuoio interior, also its spec with Fiorano Handling Package very rare. Yeah 996 C4S Im also very happy with both of this cars have been totally refurbished.
I think fun factor in Mini is same also R53 is very nostalgic for me as it was my first car back in early 2000s
Quote: That’s a sweet looking 355! The carbon sport seats, Challenge grille, and Speedlines are great upgrades. Is it Blu Pozzi? One of my dream cars (that’s possibly obtainable) is a Giallo Modena GTB with carbon seats, Challenge grille, and white Speedlines.
Reply 0
Dec 6, 2022 | 08:35 AM
That's one of my favorite Ferrari's made ! Wow , absolutely stunning color and those seats ! 🤤 🤤 🤤 🤤
Reply 1
Dec 6, 2022 | 01:04 PM
Yeah me too, I bought one of this 355 back in 2007 and ever since I sold it have always wanted to buy this spec. So I saw this car for sale 1 year ago and bought it and paid for it without seen it in person
Quote: That's one of my favorite Ferrari's made ! Wow , absolutely stunning color and those seats ! 🤤 🤤 🤤 🤤
Reply 0
Subscribe
