R50/53 Few questions about wiring and coolant
Old Mar 31, 2022 | 05:55 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
So I wanted to install a Bluetooth obd2 shift light along with my multi gauge. Buuut my car cannot supply enough power through the splitter to power both. Can I unhooked a wire from my stock obd input and run a power wire strait to it so I know for sure it's getting full power ? I seen there are 6x pins if I remember correctly in it , 2x on the bottom and 4x on the top , which one is power ?
iiiiiiiiif i cannot get the splitter working Im picking my shift light over my multi gauge but then I NEED to be able to monitor coolant Temps accurately so I will need to install an auxiliary water temp guage wich isn't a big issue BUT what coolant hoses do I need to tap into in order to get accurate coolant Temps BEFOR the thermostat opens and what mm is that hose so that I can order the correct size splice on piece. OR could I run the signal wire from the water temp gauge to ? Instead of running an auxiliary sensor n stuff ???
thanks for the help guys , it's ALWAYS very much appreciated !
but here's a sneak peak on how the cars coming...
Old Apr 1, 2022 | 05:15 AM
MiniManAdam
Community Builder
I'm going to be heading down to work on the car in a few hours. Anybody have any insight on providing more or a better source to power the obd port ?? I found this schematic but it doesn't quit match my pinout in my port.
Old Apr 1, 2022 | 05:26 AM
mrbean's Avatar
mrbean
Why not tap directly into the fuse box?
I've used something like this in the past, they make it really easy.
Amazon Amazon
Old Apr 1, 2022 | 07:57 AM
MiniManAdam
Community Builder
https://www.amazon.com/10-Pack-Add-c.../dp/B01DYQM6EO
I already have and thats whats powering my gauges BUT i need a constant 12v to the obd port...I. not worried one bit about finding a power source
Old Apr 1, 2022 | 02:13 PM
MiniManAdam
Community Builder
Another quickie.... on these adapter , the screw on them , is that to run a ground wire off ???? I think this is the route I'm gonna have to go.
SmurfNinja
29
May 16, 2016 10:00 PM
imagineary
May 16, 2014 12:54 PM
Thomas1
Dec 8, 2010 08:50 PM
free2bfl
Jan 23, 2010 02:17 PM
G. P. Burdell
Electrical
Mar 10, 2006 06:27 PM
