R50/53 Chirping
Old Aug 22, 2021 | 06:31 PM
Minivann's Avatar
Minivann
Chirping
I have an r53 and the past few days have been rough on my car. For some reason it has been making a chirping sound coming from the driver's side whenever I go past 25% throttle. It also does it when under some load. The car also surges if I hold it at 4k. Does anyone know what this could be? Is it the bypass valve or the throttle body?
Old Aug 23, 2021 | 02:38 PM
ssoliman's Avatar
ssoliman
Got a vid of sound?
tb or bv do not chirp. Or a should say I can’t see those chirping.
could be a pulley
Old Aug 23, 2021 | 07:38 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I am certainly no expert but I had and heard a similar sound you describe on my 04 MCS. It finally threw the belt. The idler pulley/bearing failed.
Possibility?
Old Aug 24, 2021 | 07:30 AM
Minivann's Avatar
Minivann
Here is a video of the car going uphill on the highway. Cruise control was on and set to 65mph. The noise also comes when rev matching as well. I rebuilt the engine at 90K. It has a new water pump, supercharger oil, idle pulley, harmonic balancer, belt, and all new gaskets.
Old Aug 24, 2021 | 11:15 AM
ssoliman's Avatar
ssoliman
Is the ac going? Guess: blower motor
Do you hear the noise from the engine bay? I’m thinking have someone rev while you record in the engine bay?
less road noise…
Old Aug 24, 2021 | 11:20 AM
Minivann's Avatar
Minivann
less road noise…
The ac is going but the noise is there even when I turn it off. I can try to get a video of the engine bay. The other issue is if i roll onto the throttle when rev matching the noise is not there. But if I quickly heal toe the pedal the noise comes back, the engine hesitates to rev and just end up backfiring.
Old Aug 25, 2021 | 07:49 AM
Minivann's Avatar
Minivann
Update. She finally threw a code. P0122 and P0222. I assume that this means I need to get a new throttle body
Old Sep 7, 2021 | 09:13 AM
Minivann's Avatar
Minivann
New update. The noise was not coming from the throttle body. the chirping was my supercharger pulley. It blew off while we were doing some tests. I switched to a 17% Alta pulley and now it is running smooth.
Old Sep 8, 2021 | 01:38 AM
nd-photo.nl's Avatar
nd-photo.nl
I would've said a pulley, and my best guess would be the idler pulley. Thanks for adding the solution to your thread, this is what makes a forum valuable!
MiniAE
Nov 11, 2009 07:27 PM
jonnieoh
Aug 6, 2008 06:56 PM
kliebss
Jul 28, 2006 10:47 AM
BearX220
Oct 24, 2003 09:23 AM
