R50/53 R53 MCS Manual Transmission Fluid Leak
Old Aug 17, 2021 | 06:24 PM
Mtb Awesome's Avatar
Mtb Awesome
So I recently replace the oil filter housing gasket and so far that fixed my oil leak. Only today there was another puddle under my car after looking at the fluid it seems to be transmission fluid due to its reddish clear appearance. Is there any place that it could be coming from other than the shaft seal. I did do a clutch a couple months ago and didn't replace that seal so do you think that maybe one of the drain bolts may have come loose or is there any other place that could cause that leak. Thanks!
Old Aug 17, 2021 | 07:00 PM
Mtb Awesome
Side where drain and fill plugs are.
Side without drain and fill plugs.
Old Aug 18, 2021 | 10:10 PM
mr.r50's Avatar
mr.r50
i learned that if your inside the transmission and that $5 seal you question if you should buy and replace that seal, that answer is yes because that will be the reason you prob have to take it apart again after your took it out the first time and thought about if you should of replaced that seal
monica117
Aug 21, 2017 02:53 PM
Big John O
Oct 31, 2014 08:48 PM
tonester
Feb 15, 2011 03:11 PM
tommy_zito
20
May 8, 2007 10:13 PM
topher evans
Nov 24, 2005 06:29 PM
