R50/53 Valeo clutch longevity
Old Dec 7, 2020 | 10:01 AM
ladsjohn's Avatar
ladsjohn
I replaced the stock flywheel and clutch in my 120K R53 a while back. It had been slipping and getting progressively worse. Went for the Valeo kit and really liked the lighter pedal feel.
Well, about 24 months and 8K miles later and it's slipping again. My wife is the primary driver and has been driving a stick for over 20 years. She doesn't ride the clutch pedal, drives it mainly as a freeway commuter. It's a little hilly where we live - but nothing crazy.
I run a 15% pulley and a sprint booster (amongst other thing - but those 2 seem most relevant).
Considering the stock setup lasted *much* longer - and I'm tuned into the slight vibration in the drivetrain with the single mass flywheel - I'm considering going back to stock. Should be a little easier to do second time around.
Has anybody had a similar experience with the Valeo clutch?
Old Dec 7, 2020 | 10:22 AM
qolor's Avatar
qolor
I had a similar problem with a Valeo kit on a customers car.
Since then, I refuse to use them. OEM LUK only.
Old Dec 7, 2020 | 11:28 AM
xsmini's Avatar
xsmini
54,000 miles so far on my Valeo with no issues. Of course I got 366,000 out of the stock set up (and still had life left in it), so I may not be a good one to compare to.
Nik
Old Dec 11, 2020 | 10:11 AM
IQRaceworks's Avatar
IQRaceworks
I've got right at 33K miles on my Valeo clutch in my 03' JCW R53. The stock clutch lasted 150k miles.
The Valeo has been great. My car makes around 225hp, and it seems to hold the power just fine. There are tons of people who run these Valeo clutch kits......it's rare that you ever hear about people having issues with them.
No matter what clutch you are talking about....if it's slipping after 8K miles, it was either defective from the factory (low pressure plate pressure), was installed wrong, or someone is slipping the hell out of the clutch.....or all of the above.
Old Dec 11, 2020 | 10:46 AM
ladsjohn's Avatar
ladsjohn
Thanks for the feedback. I've dialed back the sprint booster a little and it seems to help. I'll keep an eye on it.
Old Dec 11, 2020 | 10:54 AM
IQRaceworks
I really don't like those sprintboosters.....especially for trying to take off nice and smooth. With just a little bit of throttle travel, you get a lot of throttle opening. If you are revving the hell out of the motor every time you take off in first gear causing the clutch to slip alot......that's horrible for the clutch.
Also....if it slips under wide open throttle...it's shot and needs to be replaced.
Old Dec 11, 2020 | 03:16 PM
A383Wing's Avatar
A383Wing
Interesting thread here....I was strongly considering a Valeo clutch for the R52 JCW car....now maybe I need to rethink this considering what was posted above
Bryan
Old Dec 11, 2020 | 07:50 PM
IQRaceworks
Bryan
If I had to do it again....I would still go with the Valeo kit.
Old Dec 12, 2020 | 11:38 AM
Racingguy04's Avatar
Racingguy04
Bryan
I can't comment on the longevity because I only have about 5,000 miles on it, but look at the exedy SMF kit (https://www.rockauto.com/en/moreinfo...417171&jsn=321) the flywheel is lighter than the valeo by a few lbs and it's a few bucks cheaper. I also think that you can run more aggressive friction discs and clutch covers with the included flywheel if you want to down the road.
Old Dec 12, 2020 | 11:40 AM
A383Wing's Avatar
A383Wing
Thank you...that at least gives me another option
Bryan
Old Dec 14, 2020 | 08:15 AM
ladsjohn's Avatar
ladsjohn
I wouldn't base your decision on a single data point. A lot of people use these clutches and they are an OE manufacturer.
I'm the OP btw.
Old Dec 15, 2020 | 06:54 AM
SupeR53's Avatar
SupeR53
I've got 35k on my Valeo kit, 15% pulley, 2% overdrive pulley, CAI, chipped, AutoX regularly, no issues so far, I like the easier pedal feel too.
Old Dec 15, 2020 | 07:42 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
mine have held up with one exception, hot trackdays it will start to slip in gears 3rd and above after a few sessions when it gets good and hot. I'm running 200whp
Old Apr 16, 2021 | 07:21 AM
ladsjohn's Avatar
ladsjohn
For anyone reading this thread who is thinking about a Valeo clutch - I found the issue with mine.
It had nothing to do with the product or the installation. I sat in the car with the car's primary driver for about 2 minutes and saw why it went through a clutch in 8k miles.
"Slipping it is fine, right?". :face palm:
Looks like her driving style has regressed and some re-education is in order.
Old Apr 19, 2021 | 07:47 AM
TheBigChill's Avatar
TheBigChill
I had the Valeo on a bolt-on R53 for 60k miles without issue. Felt way better than the OEM setup.
Edit: Just saw your last post. Yeah man, I've seen some people who slip the clutch to some extent in EVERY gear. I had a guy comment on how I drive one time when I test drove a Golf: "You let the clutch out really fast in all the higher gears." Yes, I do, yet you feel no jerkiness....
Chase Robison
Dec 29, 2014 03:57 PM
mcart5
Sep 5, 2012 09:56 AM
DJDUPONT
Sep 11, 2011 10:05 PM
DWatkins
Oct 13, 2008 06:46 PM
ChiliCooperS
Jun 8, 2006 10:33 AM
