R50/53 R53 Brake Pedal Sink
Old Oct 18, 2020 | 09:43 AM
CT Hiker's Avatar
CT Hiker
HI, I am experiencing brake pedal sink when I apply the brakes and keep the pressure on. The master cylinder is full, I do not see any leaks and I haven’t done any brake work in months. The car has 182,000 miles on it and it runs great. Any thoughts?
THANKS.
Old Oct 18, 2020 | 10:41 AM
nd-photo.nl's Avatar
nd-photo.nl
Probably the brake booster which is leaking (or the connection to the brake booster)
Old Oct 18, 2020 | 01:55 PM
PhoenixMini's Avatar
PhoenixMini
What he said above. You should see a decrease in your brake reservoir. You may not see a leak if it is leaking into the brake booster, through a possibly compromised seal. Have you also check all the caliper to be sure there are no leaks down in that area. Had a slow leak on my Driver's side rear from a loosened bleed valve.
Old Oct 19, 2020 | 08:01 PM
noodlesandsam's Avatar
noodlesandsam
Check carefully, we had a soft pedal with a slow drop in fluid level - rusted hard line to left rear wheel. Replaced with cuprinol line.
Old Oct 20, 2020 | 05:49 PM
ssoliman's Avatar
ssoliman
total guess, bad or going bad master cylinder. if the fluids are not going down...
Old Oct 20, 2020 | 05:59 PM
CT Hiker's Avatar
CT Hiker
noodles and Sam for your input. I had a line weep before and thought the same thing but I haven’t seen an other leak.
THANKS
Old Oct 20, 2020 | 06:03 PM
CT Hiker's Avatar
CT Hiker
Ssoliman, Thanks for your input. I think I’m going to have to remove the master cylinder and check the seals.
THANKS
Old Apr 9, 2023 | 07:01 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
THANKS
soooo what was your fix , I have the same issue after new booster , new master , 20x times bleeding it with pressure bleeder and scwaben tool and STILL NO CHANGE !!!
Old Apr 11, 2023 | 08:14 AM
Grand-Cayman's Avatar
Grand-Cayman
You can try a scanner that will actuate the ABS during bleeding. That helped mine some, but did not fix my perpetual excessive pedal travel. I ended up installing a BMW E46 master cylinder and Willwood big brake kit on the front. The brakes are great, but too bad I still have not figured out why I am in limp mode... :(
billabongrob
May 12, 2020 03:24 AM
sevin
Sep 24, 2015 05:00 AM
ndylam
Apr 11, 2010 05:26 PM
nicklk
Classic Mini Talk
Jun 22, 2009 07:40 PM
