R50/53 transmission noise after clutch change
Old Sep 25, 2020 | 07:39 AM
Goop's Avatar
Goop
So I just replaced the clutch in my R53 with the Valeo solid flywheel conversion. I also pulled my LEFT axle to replace the CV boot. (Yes , I put that back together as previously aligned)
Clutch pedal felt great. Drove fine except slight steering wiggle coming off pedal acceleration.
ISSUE: After 10 miles or so, started hearing some noise (whirring/grinding) while in gear driving. Noise would go away once I pushed the clutch in. No distinct noise in neutral stationary pedal in or out.
UPDATE: Getting slight buzzing stationary, in neutral, pedal in & out, same with in gear. Most notable when in gear driving. Seems to go away driving clutch pedal in and/or in neutral.
NEED HELP DIAGNOSING.
Old Sep 25, 2020 | 10:58 AM
IQRaceworks's Avatar
IQRaceworks
When you replaced the clutch, I'm assuming you also replaced the throwout bearing? Transmission is full of fluid?
Old Sep 25, 2020 | 11:51 AM
Ministrater's Avatar
Ministrater
Did you seat the drive line correctly? The driver side axle will snap into place with a little persuasion.
Goop
Sep 25, 2020 06:00 AM
embiggenedmini
Jan 13, 2020 08:50 AM
MiniDeLux
Sep 21, 2012 10:36 AM
minirooferS
May 24, 2011 07:02 PM
YYC
Jun 8, 2005 06:24 PM
