R50/53 No start - solenoid fires, starter is good, battery good, alt good, doesn't crank.
This is a 2005 Mini Cooper S 6speed manual, I don't know a lot about these cars and I'm guessing that it's an R53. I've been bump starting this car for about a month. It has a new starter, starter relay, no service engine light, the battery is good, the alternator is good. If I turn the key in the engine the solenoid fires off for a bit then quits. If I hot wire the 16 gauge black\yellow wire starter terminal the engine cranks but doesn't fire with the key in the running position or in the starting position. I think the problem is the 16 guage wireblack\yellow wire, but I'm not sure and I don't know where it goes and can't chase it without pulling the whole engine apart.
If you've seen this problem before or know where that wire goes, or know more than I do about my car I'd appreciate your input.
The symptoms if trying to start it normally: the solenoid fires briefly, the head lights flash, some times the immobilizer or something (I really don't know what or where that is) will beep, and when I take the key out of starting position the dash gauges will fiddle around, and the clock and tripometer will reset. If I bump start it no service light and runs like a champ.
Thanks!
Thanks!
Isaac Boyle
Aug 6, 2020 05:29 PM
snowballs
Dec 23, 2019 05:41 AM
knighty87
Mar 6, 2011 06:10 PM
skillet
Mar 28, 2008 09:14 AM
JSWMCS
Nov 17, 2006 02:56 PM
