R50/53 Let's talk tuning . I'm about to purchase a tune but....
Old Feb 24, 2020 | 01:09 AM
  #101
adriancl's Avatar
adriancl
Originally Posted by MrBlah
there's a big difference between dyno brands, up to 15 %. Yours tested the same as mine but I have a lot more mods
I do not know what progress the RMW people have made now, but I have disassembled two old tuned files made by them and in my opinion their approach is strange, some changes I think are wrong.
I suspect they use the Bytetronik software as their basis, but they lack some essential maps for proper tuning.
Scaling some 640cc injectors is no easy task.For a supercharged engine the optimal AFR in Open Loop(full throttle)is somewhere between 11.2-11.5.Under 11AFR mixture is too rich and loss of power.If you run AFR under 10, for sure less power and less torque.I saw a lot of tuned file made for R53, but the BIG mistake of the tuners is to try to modify this DME sw using Bosch strategy,totally wrong , because is a Siemens , and most important is Siemens EMS 2000sw, not Siemens MS sw or other Siemens versions.
No one cares that this engine don't have MAF sensor(Mass air flow),EMS2000 use MAP sensor values to calculate the air mass used by engine.
Also Ignition strategy is totally different than Bosch or other Siemens sw.
If you have your tuned file , I might try to adjust the power and torque on high values with a good AFR, free charge for you.I need only AFR logs, and SFT trims logs on your car, and of course a complete list of engine hw. changes.I assume you injectors are not rescalled in the right way.
I guess you have a tool to read and write DME.
Old Feb 24, 2020 | 04:18 AM
  #102
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Originally Posted by cooper48
We both tested on a Dynojet so I have to believe the results should have been similar. I can understand that you would be upset given the level of your mods but I don't have an explanation for you. I do know that I have pulls pre- and post-mods using the same dyno and conditions therefore have a solid apples-to-apples comparison and dyno reports to confirm it. Honestly, given your extensive mods I would have expected you to have a much higher horsepower reading than 191.
My car is tuned for track use, 10.5 AFR at high rpm. I have seen big differences between dynos, this one was set to read low for time trial whp/weight classing, we got my peak hp down to 181 keeping the car in TT5
I'm probably setting up a new car in a few months, fiat head, race cam, better lsd, and all my suspension and safety gear moved into a non sunroof car
Old Feb 24, 2020 | 05:05 AM
  #103
MrBlah's Avatar
MrBlah
also it's my understanding that the RMW tune alters the ignition tables a bit, I believe that is where the big gains are but don't quote me I'm not a tuner just a driver
Old Feb 24, 2020 | 08:10 AM
  #104
MiniManAdam's Avatar
MiniManAdam
Community Builder
SWEEEEEEEEEEEET.
Adrian has finished tuning my car and I am very impressed . I will make a new post soon in depth about it and my results . I now have no check engine light on and there are no codes present AT ALL. So with all my mods,that's awesome ! The car feels more responsive and it holds an idle perfect . Before ,untuned at idle every now in then if it sat for a few min idling it would start to get a little choppy sounding almost like it had a cam in it but just a tiny tap of the gas would make it start idling correctly again and it wouldn't start the choppy idle again until maybe later in the drive cycle IF you for some reason let it idle again for an extended period of time.. my mods are again btw
15% pulley , light weight crank , real Cai , 380cc injectors , larger intercooler , msd wires and coilpack with ngk range colder plugs , header with no cat and pacesetter exhaust , throttle controller and a tune by ADRIANCL . Possibly more to come 🤔🤔🤔
Heres a little rip through the airport tunnel.. HEADPHONES ARE A MUST , volume WARNING
https://youtu.be/yY9GO0JMjAo
Old May 29, 2020 | 03:54 AM
  #105
gowest's Avatar
gowest
I just stumbled upon this thread after getting responses to a post of mine in the Drive train section and a PM recommending adriancl . I have sent him a pm, hoping he can tune my car.
Old Jun 12, 2020 | 03:33 PM
  #106
aupshon's Avatar
aupshon
Originally Posted by MiniManAdam
SWEEEEEEEEEEEET.
Did you ever post a follow up on your results? Would really like to hear about the changes!
Old Jun 12, 2020 | 05:09 PM
  #107
MiniManAdam
Community Builder
yes, theres another article from me, long story short.... there was a huge change in performance and drivability. Cars still running perfect today and ille actually be having adrian retune for my more aggressive mods I just ordered.
https://www.northamericanmotoring.co...-adriancl.html
Old Jun 12, 2020 | 06:18 PM
  #108
wolf3142's Avatar
wolf3142
I will also vouch for an adriancl tune! He was a pleasure to work with and incredibly knowledgeable. The car is so much smoother now. Everything seems to play together much better than before the tune. He also helped with the header CEL code. Cheers!
Old Jun 13, 2020 | 02:40 AM
  #109
aupshon's Avatar
aupshon
This is amazing to hear! Great feedback from all members. I'll pm him to assist me with a remote tune too.
Old Jul 1, 2020 | 05:32 PM
  #110
Luters85's Avatar
Luters85
Originally Posted by adriancl
Good tune can be done around 300$, here is my recommendations from my long experience tuning these cars.
Tools need :Data Logger, can be cheap INPA or any other tool.Flashing tool, the best way is MPPS V13, cheap tool around 20$.
Need data logger so you can read Boost pressure , SFT and LFT.Under 16PSI boost , the power gain decreases quite a bit.
Flashing tool MPPS can be used with Win XP,Win7 , Win10,to read original file and write the tuned file.
R53, Supercharger pulley -15%,can be tuned with stock injectors 320cc for 200HP.Pulley price with is around 100-120$.
R53 , Supercharger pulley -15% or -17%,injectors 380cc.I used most of time Bosch injectors 0280156063, plug and play, no need adaptors,price for four injectors around 100$ new ones.Can get 225HP-230HP with the right tune.Used injectors can find on Audi TT equiped with 1,8T BAM engine 225HP.
About dyno test, from my experience I recommend a test before and after tuning on same dyno.This way you will find out exactly the power gain.Sometimes you will be surprised to find that your stock car doesn't even have 163HP,most often 150-155HP.
For this reason many dynos are called heartbreakers.
For mare details you can pm me.
I just try to pm you but your inbox is full... regarding the tune of course. 👍🏽
Old Jul 1, 2020 | 07:04 PM
  #111
robj's Avatar
robj
Opps.
Old Jan 24, 2023 | 05:49 AM
  #112
tb205gti's Avatar
tb205gti
@AkumazetoI hope you can understand values from this logs table, is a professional log made with a special Dataloger which allows data to be saved as csv file.Logs are made on same car as MiniManAdam , same hw changes.Lok on knock values, on SFT, on rpm, gas pedal position ,Throttle angle.
Looking at the logs, it is quite impressive that there is no LTFT or knock.
However; Why is the AFR 14.5:1 and a full pull log - did you go for stoichometric? Or did you disable all additional enrichment maps to make sure the injector scaling was done correctly ?
Old Jan 26, 2023 | 03:16 PM
  #113
MiniManAdam
Community Builder
If you have any doubt on how my car runs watch this video at 11 minutes in I do a wide open Pole 0 to a 100 plus if you can keep an eye on my air fuel ratios you'll see they are perfect and this is why I'm spraying meth too.
Id trist adriancl tuning my car , with ANY MODS. ANYDAY !
he's now tuned my car multiple times for its various as well as tuned another mini I had and will be tuning my aero mini I recently aquired..
https://youtu.be/TNvRUwowEYY
https://youtu.be/0x8p05YaOZ4
suntaepark
May 6, 2013 04:33 PM
Enzof104
Feb 4, 2013 09:31 AM
guitfiddler
Oct 30, 2009 08:17 AM
BoomerMCS
Jun 29, 2008 09:46 PM
littlehandegan
Sep 12, 2007 06:02 PM
