R50/53 Let's talk tuning . I'm about to purchase a tune but....
Old Feb 13, 2020 | 05:33 PM
  #51
MiniManAdam's Avatar
MiniManAdam
Community Builder
Originally Posted by Akumazeto
Smdh are any of these tunes based on the car with a wideband and logs or just what are your mods canned tuned? What is the cost of these TOONS? If you guys dont have widebands installed your more trusting than I would be thats for sure. How is cold idle being handled then cold idle in places like Wisconsin where its -20 here today. I guess @MiniManAdam will find out if when he comes to a stop sign or light his afrs start leaning out into the 16 then 18's then back to the 14.7 area to compensate via stft dipping -25 jumping +25 setting a light etc or it dies at light or when he takes off. Without a gauge you will never know whats going on and it will happen. More so if you dont have the VDO DME. Especially in Wi where the weather can change 50 degrees over night or in the same day like today. Warm idle etc. I just have a feeling you guys are either getting very basic stuff or walking a dangerous line. Who is checking knock voltage? If your still 10.8 at the top of 3rd you haven't gained much other than a smoothed yo yo area and likely a sprint booster like setting which is what fools most people into thinking they gained power. Adrian are you leaving the pedal linear or cheating it so people think they have gained more than what they have. I mention this because with these light of mods there is not much to be gained with a tune other than just a smoothed area under the curve with the factory had its yo yo f up and a sprint booster effect. That normally makes people go wow its so much better. Reality is you give the throttle 10% but now its programmed to open 50% If thats the case it bothers me because you really have not gained anything and its basically just a lie.
If you guys dont have a wide band on to watch you are flying blind and you can just think I am a douche but many many people have toasted the w11 over the years on this forum from bad tunes or not paying attention or thinking it was just a simple 300 bucks and I am good forever and dont need to pay attention. Anybody who doesnt require a wideband is automatic suspect. Its the number one tool needed. @BlwnAway knows this.
Understood . I'm not a tuner so I cannot answer it . But I think he has presets for the mods to adjust the ECU accordingly . This isn't sapose to be a big HP tune . I upped my injectors and alot of others things are different than stock. He also tuned out my rear 02 for no cat so I can pass local emissions instead of registering my car to my cottage . He did not touch the pedal I can tell , I have played with my pedal tuner and even a little bump up makes a huge change on how fast the car comes into wot. It's how much better the car pulls during wot is what matters to me and from what my butt says yes.
There is another member who has wide band and a Dyno for before and after Adrian's tune so he can chime in once finished also but as of sofar he too is impressed . Sorry but I don't feel comfortable talking about what others charge but I can say it beat out any others tunes price and imo was easiest route possible .
Old Feb 13, 2020 | 10:09 PM
  #52
flyingart's Avatar
flyingart
@Akumazeto
I do have installed a wideband and 4x EGT. Both from innovate.
And I logged the tuning from on my setup Adrian.
The result and the comment from my engine builder (Dr. Krumm): "this guy knows what he is doing".
a few loggs in Attachment as an example.
Regards
Dominik
File Type: csv
File Type: csv
Old Feb 13, 2020 | 11:32 PM
  #53
adriancl's Avatar
adriancl
@Akumazeto
I agree with you about AFR , but is a must have for a car with big hw changes on engine,mean 19%-21% SC pulley, race camshaft,bigger injectors 550cc,turbo conversion and so on.MiniManAdam have only 15% SC pulley ,decat and 380cc injectors.Easy for me to tune the engine in this configuration,no need AFR Gauge, i tested my tunes for this configuration along many years.Why to spend 200$ for an AFR Gauge???Not necesary.About pedal tuning, also you're wrong.I don't use pedal tuning, i make important changes on sw maps to get maximum power engine in safe area.About Knocks, maybe you don;t know but Siemens sw is not Bosch sw,Siemens sw contains many elements that protect the engine against knock danger.Will see only 19 maps which regulates and protects against.
I hope you can understand values from this logs table, is a professional log made with a special Dataloger which allows data to be saved as csv file.Logs are made on same car as MiniManAdam , same hw changes.Lok on knock values, on SFT, on rpm, gas pedal position ,Throttle angle.
Anyway , if you have Winols official version i can send you tuned file(If you agree to pay for the file) for analysis and I look forward to your criticisms.In general it is easier to criticize than to build, criticizing a tuning without analyzing it is not the most correct attitude.
Old Feb 14, 2020 | 06:27 AM
  #54
Akumazeto's Avatar
Akumazeto
I'm currently using Link ecu but have used bytetronik software which is similar and I had the vdo ecu. I also didnt say you were using pedal changes so I Cant be WRONG as you stated. I was wondering if you were. I am aware of how your logging and its similar to bytetronik logging. I will criticize any canned tune solution as its not customized to anyone persons car other than you assembling data throwing it into a cart and sending it basically. My car is heavily modified so maybe I think different but most of these people didnt even need a tune at this level of modification. At some point this will all blow up just like it has for the other people offering the same thing you are offering. Its all well documented here on the forum. Though most of the people involved are now banned. Any tune without direct AFR feedback to me is rubbish. Thats just my opinion.
Here is a modded jcw file for anyone who wants to look at it.
File Type: rar
Old Feb 14, 2020 | 06:47 AM
  #55
Akumazeto's Avatar
Akumazeto
I just looked at that log and I CANNOT BELIEVE how much timing you are running up top. I am running that much with 100% m1 controlled by a aquamist set to 35% idc
The log also looks identical to a Bytetronik log fwiw
I'm just going to bow out here. Good luck folks and happy motoring. Life is to short to worry about crap like this.
Old Feb 14, 2020 | 10:40 AM
  #56
cooper48's Avatar
cooper48
Update: Adrian provided me with a GP-tuned MS5150 ECU. I also swapped to 380cc injectors. My original dyno run produced 175.67hp at the wheel. The second dyno run today was 193.50hp for a net gain of approx. 18hp. Run condition was 51.30F, 29.93 in-Hg with 30% humidity. A/F was spot on. Unfortunately, I wasn't able to gather torque readings because of an electronics incompatibility issue with the speed shop's dyno (it's not an import shop). Just from my butt dyno I would say there's a substantial torque difference and the top-end is quite a bit better and very smooth. Makes it really easy (and fun) to pass other cars on the freeway in 5th gear at 70mph. Bear in mind that this is on a 130,000 mile 2004 stock MINI with a 15% pulley but without headers/exhaust or a CAI.
Old Feb 14, 2020 | 03:55 PM
  #57
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
how are you logging? My current tune was done by RMW and then further tweaked by a couple of others I don't have a good way to log though. I dont consider it canned as RMW tweaked it for my mods and AFR logs.
Car has 100+ trackdays on it so I'm not terribly worried, it's still pretty rich and only makes 190 whp with cam/header/17%/620cc injector.
Old Feb 14, 2020 | 04:01 PM
  #58
Akumazeto's Avatar
Akumazeto
Well given that his log he posted is the exact same format as Bytetronik I am going to say he is using that to log. This feature is not car specific. I mean its to the tee the same layout spacing everything. The car doesn't have spots for multiple innovate wide band columns thats for sure. Something is not right here at all. He is using winols to program edit and insert vin numbers but almost guaranteed he is using their dongle. Here is a warm idle bytetronik log for reference. I am not saying he is not doing what he says I am saying there is not proper transparency here is all. If anyone is wanting I can post all the factory files here and instructions on how to load them on your ecu for FREE
File Type: csv
Old Feb 14, 2020 | 04:21 PM
  #59
Akumazeto's Avatar
Akumazeto
Originally Posted by flyingart
@Akumazeto
Regards
Dominik
What EGT setup are you using and pics on install please. Interested in this setup.
Old Feb 15, 2020 | 05:17 AM
  #60
MiniManAdam
Community Builder
If those are your only mods , are you running e85 ???? Why such large injectors ? I cant see how they could possible be at the correct duty cycle..
I'm sure it's running rich because they can't cycle down those injectors enough and it's running rich causing loss of power. But atleast it has been safe if it's had that much time on the track..
Old Feb 15, 2020 | 08:34 AM
  #61
Akumazeto's Avatar
Akumazeto
um Jan at RMW is the leading developer for this platform. I am sure he scaled it just fine in dimsport. You also need 1000cc injectors to run e85 properly in these cars. Jan would have left it a tad rich on a remote tune on purpose. That being said thats why everyone should get a wideband so they know were they are at. If you had your rear o2 tuned out and have no cat throw a widbenad in grab the innovate unit that shows boost and afr and kill 2 birds etc. You should also read the posts from the w11 devloper to see why the engine is tuned the way it is. He also redesigned the pistons with RMW to offer what he originally wanted. Let me dig up the threads from Alex.
I tagged Jan hopefully he will come into the thread and set most of it correct.
@Revolution Motor Works
Old Feb 15, 2020 | 08:40 AM
  #62
Akumazeto's Avatar
Akumazeto
Old Feb 15, 2020 | 10:17 AM
  #63
MiniManAdam
Community Builder
Correct me if I'm wrong but isn't it optimal for injectors to run at around 80% duty cycle ? I mean sure it will scale them but a smaller injector would scale more accurately . I'm sure I'm wording it wrong but you get what I'm saying ?
Do you then too need a larger fuel pump for the e85 and at what hp does the stock pump handle on regular gas then ? Just curious .. it seems this stock pump is pretty strong , what is it's lph ?
Old Feb 15, 2020 | 11:12 AM
  #64
BlwnAway's Avatar
BlwnAway
As far as scaling is concerned, the difference between using an injector that runs at 50% to one that runs at 80% is so minimal when it comes to its efficiency and spray characteristics, that it would only really matter in a race or hyper accurate tuning situation.
Better to be slightly less efficient/tweaked, than to run out of fuel or buy injectors twice if it's not needed.
As far as the stock fuel pump, figure about 350 to 400 WHP with pump gas, not sure about e85, but a good guess would be 300 ish.
Something as simple as the Deatschwerks high flow pump will actually cover you for HP over that, probably 550 to 600.
Old Feb 15, 2020 | 11:24 AM
  #65
Akumazeto's Avatar
Akumazeto
love mine picked it up from Collin. Prepping for e85 myself
Old Feb 15, 2020 | 11:36 AM
  #66
MrBlah's Avatar
MrBlah
I was going to run e85 but there are no stations here and none near the tracks that I run. the car burns 1/3 a tank per session going to e85 would be a major logistical challenge with 4-5 sessions per day
Old Feb 15, 2020 | 12:01 PM
  #67
Akumazeto's Avatar
Akumazeto
yeah in Wisconsin its everywhere and cheap but its not always 85% so its best to run a sniffer and run a base tune on something like VP e85 so know its pure then let the sniffer take over and adjust the map.
Old Feb 15, 2020 | 02:00 PM
  #68
BlwnAway's Avatar
BlwnAway
-Lack of e85 locally
-Inconsistency at the pump
-Fuel system upgrades, at my HP levels (pump and injectors)
-No flex fuel option for the factory ECU (that I'm aware of)
Are all reasons that I'm sticking with W/M injection with a 75/25 mix instead.
Running 75% methanol will give me enough fuel enrichment I should be able to stay with my 650cc injectors up to 400+ WHP, and the 25% water will give me extra cooling effects.
Plus, it's not that difficult to fill a couple of 5 gal fuel jugs with methanol as needed every 5-6 months.
Old Feb 15, 2020 | 02:19 PM
  #69
Akumazeto's Avatar
Akumazeto
you running again? I actually scored this from a snowmobile team for 150 so major score for me. I turned it upside down so air cant get back in when I take some out.
Old Feb 15, 2020 | 03:37 PM
  #70
BlwnAway's Avatar
BlwnAway
The car itself was never not running, but yes the Aquamist system is finally working properly, I didn't get it sorted until Nov. because of their delays and customer service, but all is well with it.
Old Feb 15, 2020 | 03:47 PM
  #71
Akumazeto's Avatar
Akumazeto
I dont have much positive to say about Richard. I think I confused yours with Evabomber
Old Feb 15, 2020 | 06:26 PM
  #72
BlwnAway's Avatar
BlwnAway
Yes, while the Aquamist has many great protective features, which can be a real plus if tuning for the W/M, the process I had to go through because of a faulty part was pretty much a nightmare.
Far better customer service when Jeff Howerton had the US distribution.
I'll go into all of that next time I update my build thread, been a slow winter for physically working in the car, so no real changes to report on, therefore no new updates...
Back to this thread.....
Old Feb 15, 2020 | 07:00 PM
  #73
Akumazeto's Avatar
Akumazeto
He is a **** no need to sugar coat it. He responded to me once drunk off his **** made a huge **** out of himself then the next day tried to act like I was the issue. Dude makes a nice product but he is a mental case.
Old Feb 19, 2020 | 05:28 AM
  #74
MiniManAdam
Community Builder
I'm having troubles !!!!!!!
my rear 02 was sapose to be tuned out so I don't have 2 cel related to not having a catconverter . After tune light was still on and codes were present , so did another tune and light was off so I thought all was ok...went to do my emissions to get fully legal and I flunked with flying colors . Cel is off but those 2 ****ing codes are still present .
Wtf do I do now ? I've never had a tune where I've had this issue....wtf ?
The codes that won't go away are p2096 and p0136
Old Feb 19, 2020 | 09:50 AM
  #75
MrBlah's Avatar
MrBlah
never had o2 sensors coded out on mini, but on my BMW the tunes turn off the check engine light, but the code still exists. All the do is change the light behavior
