R50/53 Car Misfireing
Old Jun 28, 2019 | 06:27 AM
Braeden Stillabower's Avatar
Braeden Stillabower
Car Misfireing
Hello, I have a modded R53 that has begun misfiring under hard acceleration. First I'll give a list of my mods.
- 15% reduced supercharger pulley
- Airtec CAI
- Miltek sport headers
- Miltek sport Cat-back
- NGK spark plugs
The misfiring started happening around the time I installed my CAI. At first the car was running fine but quickly started to misfire, use a lot a gas and generally preformed worse. I figured thos would be an issue with my ignition so I replaced my leads with NGK leads and my coil pack with another OEM coil pack. This fixed a lot of the misfiring but the car still seems to not be running the best.
Could it be that my car requires a tune or is there something else I didn't think of that could be causing this.
Also sorry is I posted this in the wrong spot.
Old Jun 28, 2019 | 07:21 AM
OCR's Avatar
OCR
I'll bet the "car" isn't misfiring, I'd bet it's the engine..!
Do you have any idea what you did to the fuel mapping adding all of those free flowing parts ? You've leaned the system too far. You now need more fuel to go with the newly added air flow..!
Mike
Old Jun 28, 2019 | 08:06 AM
gumbedamit's Avatar
gumbedamit
- Airtec CAI
- NGK spark plugs
You putting the OEM coil back on should give you a clue. Sometimes all those After Market bolt-on's make things worse.I would go back to the stock CAI and see what;s what. All those bolt-ons you have should not require a tune..
Old Jun 28, 2019 | 08:13 AM
ItsmeWayne's Avatar
ItsmeWayne
Although many things on modded Mini, can cause misfire.
Air leaks in the intake, fouled plugs, failing cam position and or crank position sensors. Dirty map sensor, worn out valve guides, causing the valves not to seat. Bad fuel to air ratio, should be 14 to 1. And quite a few other things.
First step is to get a scanner on it, to detect codes.
Old Jun 28, 2019 | 09:42 AM
Minibeagle's Avatar
Minibeagle
Could be as simple as worn plugs, too. Did you check them?
I had a misfiring issue that would occasionally result in a thrown code on my 06. It would always happen under heavy load (pushing hard on gas pedal). Checked the codes and found that the misfire was on cylinder 4. Pulled the plug and found that the center electrode was badly worn. Replaced all plugs and has been running smooth ever since.
Paul830
49
Jul 30, 2013 12:49 PM
chows4us
Off-Topic :: Autos
26
Nov 1, 2006 12:16 PM
AK430
Apr 3, 2003 05:51 AM
MG-BGT
Apr 2, 2003 08:32 AM
