R50/53 Clutch release rod bushing replacement?
Old Jun 18, 2019 | 10:35 PM
alconk's Avatar
alconk
I finally found where my leak was coming from on my R53 and it turns out it's leaking out of the clutch release rod where it enters the transmission case. From the bushing I guess but how do you replace that?
Old Jun 18, 2019 | 11:56 PM
Blue R50's Avatar
Blue R50
It sounds like a bad slave cylinder. I haven't done it, but I read up on the bleeding procedure and it isn't fun.
Old Jun 19, 2019 | 12:25 AM
alconk's Avatar
alconk
It's not leaking from the slave cylinder it's leaking from the bushing.
Old Jun 19, 2019 | 12:34 AM
alconk's Avatar
alconk
Old Jun 19, 2019 | 03:09 AM
RudeJoe's Avatar
RudeJoe
There is no oil in the bell housing in that area. That’s where the clutch is. It must be coming from the engine (rear main seal) or the transmission front seal if it’s coming from inside that area. Either way you’ll have to take the trans out to fix.
To further diagnose- any evidence of oil at the engine/trans seam? There’s a very small hike at the bottom of this seam.
Old Jun 19, 2019 | 08:45 AM
alconk's Avatar
alconk
No nothing at the bottom it’s coming out of the bushing then runs down to the bottom and drips off. After I cleaned everything extremely well it was easy to see.
Old Jun 19, 2019 | 08:48 AM
Blue R50's Avatar
Blue R50
Perhaps you should post a picture of what you mean because I can't think of any bushing that would leak fluid.
grahamquanta
May 5, 2019 01:47 PM
Brownshoe
12
Apr 12, 2019 06:27 AM
sprp85
Apr 30, 2018 11:56 AM
Andrew Riley
Dec 31, 2015 08:23 AM
mini_macky
Suspension
Mar 7, 2007 12:59 PM
