R50/53 R53 Mini Cooper s grinding sound?
Old Feb 16, 2019 | 02:57 PM
Russter500's Avatar
Russter500
I don’t really know what to call it but I’m attaching a video to show it, it’s like a kind of grinding loose sound? Almost like gears meshing roughly. I’m worried it may be my tensioner for my timing chain, but I’ve heard it can also be a clutch bearing? I know it had a new clutch install about 30k miles ago. In the very beginning the engine is sort of ticking too? Is that normal? I checked my purge valve and it’s fine. Plus the sound seems to be from under the inter cooler. Any ideas? Thanks!
Old Feb 16, 2019 | 03:10 PM
Fastlane's Avatar
Fastlane
Hard to tell from a video.
You can usually doagnose a rattling clutch by pressing in the clutch pedal.....if the rattle stops when pressed, it’s probably the throwout bearing. My car does this and my last r53 did it.
if that’s not it, then I would check your tensioner and idler pulleys......are they going bad?.....if the bearings are going out, they can make a grinding noise. Release the belt and spin the pulleys to test.
if your car has a lot of miles, it’s a good idea to change out the timing chain tensioner anyway. The part is cheap and it’s easy to do with the passenger front wheel removed.
hope that helps!
Old Feb 16, 2019 | 03:11 PM
sandplasma's Avatar
sandplasma
I had a very similar issue and it turned out to be a seized alternator pulley. Are you having any battery/power issues?
marsda
Apr 22, 2015 08:39 PM
Roeri
22
Dec 18, 2007 11:11 AM
skywarrior
Jul 30, 2006 11:13 PM
skywarrior
Jul 27, 2006 10:38 PM
frank miller
Mar 13, 2006 02:17 AM
