R50/53 Interior A, B and C pillar removal help
Old 08-18-2018, 09:43 PM
Rogers90's Avatar
Rogers90
Rogers90 is offline
I am going to remove in interior panels to have them vynal wrapped, but I have no idea how to. There are videos for 07+ and mine is an 06, if anyone has like a step by step or any instructions on how to do it that would be awesome. I’ve looked all over and can only find stuff for removing the outside pillars. Thanks
Old 08-18-2018, 11:26 PM
audihere's Avatar
audihere
audihere is offline
I saw some videos on YouTube for removing the pillars in R53. Search headliner removal.
But in the videos they didn't seem to have the nylon strapping still attached to the pillars. Probably cut off previously.
On the A's, I was able to get a torx in there after popping it off with plastic tool and unscrew the Nylon straps. Reused them too.
B's were pretty easy.
C's had 1 Nylon strap each and I had to cut it. Ideally if you can unclip the metal clip from the car that's the best.
If you reuse the Nylon straps, screw the loop to the pillar and then press the metal clip to the pillar. Then you can simply press the entire pillar back onto the car.
Old 08-19-2018, 07:02 AM
Rogers90's Avatar
Rogers90
Rogers90 is offline
Maybe a stupid question, but do I need to unhook the battery?
Old 08-19-2018, 11:36 AM
audihere's Avatar
audihere
audihere is offline
I don't think I did for that. There are some airbags all over the place, so it couldn't hurt.
Old 01-22-2022, 07:38 AM
chipbagjohn's Avatar
chipbagjohn
chipbagjohn is offline
I'm trying to drop the headliner to get access to the antenna, I have tried to remove the c pillar covers and made a mess of it. They are still not off the car, but I think all the tabs are now broken (I don't think the 0°F temps have helped.) I think the nylon strips are the only thing keeping them on now, I think everything else has snapped off. I hope JD Weld will help me out there.
Does anyone know what the nylon straps are for and is it a problem if you cut them? If cutting them isn't the answer, how do you get them off?
Old 01-22-2022, 08:12 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
I think the nylon straps are tethers to contain the panels when the airbags deploy.
You might be able to drop the back of the headliner enough to access the antenna connections, mounting screws, and rear sunroof drain tubes, without completely removing the C panels from the car. The front sunroof drain tubes should also be accessible with the A pillar trim loose/tethered and the headliner partially dropped.
chipbagjohn (01-22-2022)
Old 01-22-2022, 09:52 AM
Here2Go's Avatar
Here2Go
Here2Go is offline
NAM Community Team
For what it's worth - I was able to remove my entire headliner without removing any of the pillars and without/avoiding creasing the headliner panel itself.
I removed/detached the sunroof molding, inclination sensor cover and gently pulled the tops of pillars forward while gently bowing/pulling down on the center and ends of the headliner panel.
Of course removing the entire headliner also involved removing; rear view, grab handles, light etc. In your case it may be less.
Even though it was a warm Spring day.....Care and patience were key for me. Perhaps...even "lucky".
Old 01-22-2022, 12:50 PM
jjcsnlynn's Avatar
jjcsnlynn
jjcsnlynn is offline
The nylon tethers are to keep the panel from flying if the airbag goes off. I used a cutter pin tool and some force to unhook them and pull them off the frame. They are clips, so you have to get underneath the clip and bend them some.
Old 01-23-2022, 01:47 PM
chipbagjohn
I removed the pillar cover, a bit of a mess really.
I took a couple of pics of the nylon strap and how it is connected to the clip. I hope these help someone.
ssoliman (01-24-2022)
astroBlackMetallic_Mini
07-18-2012 07:14 PM
rdmini06
06-17-2011 04:13 PM
gfoye
06-17-2011 07:19 AM
FlyingZ06
07-17-2008 07:29 PM
whiteyanderson
05-11-2008 09:47 PM
Quick Reply: R50/53 Interior A, B and C pillar removal help
