which way does the motor rock?
I need an answer quick, trying to locate the WB O2 sensor. Which way does the motor rock when you step on the gas?
I reason the cylinder head rocks towards the coolant expansion tank which make the crack turns clockwise viewing at the crank pulley. Please confirm. |
Duh! I should had just calm it. Use your head! :roll:
The easiest to find this answer is to search for a photo of the belt. I actually thought of looking at it but only the wheel well cover is in the way. Here is the answer - engine rotate CW so it rock away from the radiator as the tensioner is the last in the tensioned chain https://cimg2.ibsrv.net/gimg/www.nor...54274361f0.jpg |
Just learned something new:thumbsup:
Originally Posted by pnwR53S
(Post 4385052)
