R50/53 about to buy used 03 R53
i just checked on carfax and shows below
01/29/2017
82,154 mi
California Inspection Station
Failed safety inspection
Passed emissions inspection
10/17/2016
79,035 mi
what causes failed safety inspection? is it big deal?
01/29/2017
82,154 mi
10/17/2016
79,035 mi
Good question. Disabled, missing seat belts? Non-functioning brake lights? Seems there should be an inspection report somewhere. I would make sure the title is clean (not a salvage title). If the title is okay, I guess I'd have a good independent MINI shop inspect, and correct any issues.
If the title isn't clean, you should be able to get the car for nothing, but make sure whatever issue has been fixed.
Some times it could be something silly.
For instance. My wife took one of her cars to get inspected and it failed due to having a rear light out. Changed the bulb, took it back and 5 minutes later it passed.
Another time it failed was due to them checking the headlight bulbs (new thing in VA). I did a HID retro fit but since it wasn't the bulb that is DOT stamped on the headlight it failed. Went home, put stock bulbs back in and it passed...
Might not necessarily be a bad thing or huge problem. A lot of times they try and ding you on everything so that they can charge you $49 to change a reverse light.
-Nigel
-Nigel
Vendor
I agree could be anything as simple as wiper blades. So it would be totally worth the investment if you are serious to have a shop do a prepurchase inspection so you know what you're getting into.
It's interesting that the car is failing safety inspections since safety inspections aren't required in California.
The only reason I know of are for salvaged cars. They require a brake and lamp inspection(a misleading name for a CA safety inspection) to re-register the car after being rebuilt of repaired, and maybe before registering a SCV/kit car. Out of state car purchases, or registering an out of state vehicle, require an inspection for VIN verification and to make sure the car is CA legal. Not sure if it also requires a brake and lamp inspection.
What does the carfax show for registration history or accidents?
