Suspension Struts to get w/ Swift Spec-R springs?
I know the damper question has been asked innumerable times, but this time I ask it knowing that I want the Swift Spec-R springs. I have read favorable reviews on the quality and performance of these springs, and the drop looks perfect to me.
That said, I'm curious as to what struts would best compliment this spring. The Bilstein B4 looks like a good strut, but it's touring class and these springs are certainly performance so I don't know if they would cooperate with each other. I've also read the Koni FSD's are fantastic performance struts, but they also don't work well with springs that have any kind of drop. For reference, the drop is 0.7" (18mm) and 0.5" (13mm) F/R.
Any thoughts?
Any thoughts?
Koni Yellows, they are on sale right now and are a great shock with an adjustable rebound rate.
FSDs are not compatible with lowering springs, but do ride great on stock height setups.
Don't forget to cut your bump stops down, otherwise you'll be on them through every corner and over every bump.
I don't know about the swift spec r springs but koni fsd's and stock springs are great for spirited street driving while having better than stock ride comfort. I even autocross on them and they work but if I planned on doing more autocross or track days I'd go with lower springs and koni yellow adjustables.
Don't pair the FSD's with the Swift Spc R's. They are designed only for use on stock springs. If lowered, you don't get the full benefit of their design and some people have claimed that they fail. A lot of my friends have paired the Swift's with Bilstein Sports and said they were perfect! I'm sure the Koni yellow's work well too. Great springs, but they need the right shock to control them or they will be too bouncy!
Everyone's ideal level of comfort is different, so it's a bit hard to quantify. I'm currently on FSD's with stock springs. I ran Swift's for a while but my local roads suck bad, so yeah, there is a trade off. Swift/Bilstein?koni combo will definitely be firmer than FSD and stock springs, but they also handle a lot better. Only you can make that determination. If you don't have a lot of broken pavement and harsh expansion joints on your roads, the Swift's would probably be fine. Either way, I recommend the Fat Cat bumpstops. They even make one's that specifically work with FSD's.
Curious what the threat starter here sevin went with... I'm also looking at Bilstein HDs.
With a moderate drop like the Swift springs (or actually trying to source a set of JCW springs) is it really necessary to go with the Bilstein SPs?
Swift advertises the Spec-Rs as being designed to work with stock dampers (albeit at their limits), so I would imagine an upgraded stock damper replacement (Bilstein HD) would do just fine, no? I have also read some other accounts of people using HDs with moderate (less than 1" drop) springs successfully.
btw, I'm not ruling out the Koni yellows, but have just heard the Bilsteins are near indestructible, whereas I've heard some mixed reviews of yellows being difficult to install, wearing out, etc.
I've had Koni Yellows and Swift Spec R springs for a while now.
Made the decision since the Swifts are the only regular springs with a linear rather than progressive rate. Also they reduce the car's natural understeer tenancy with their spring rates. After having Koni's on my Miata I knew they'd work well with autocross and track days. Not the most comfortable but certainly more tolerable than any coilover around $1,000 or less.
Smitha6
Suspension
17
03-22-2016 07:51 PM
1004ron
03-22-2016 09:39 AM
