R50/53 HELP Please!! I hit something.
Old Sep 3, 2004 | 10:38 AM
Nando's Avatar
Nando
Today at lunch, I was going thru a drive-thru, and on my way out, I hit a sidewalk curb. It made a loud bang noise, and when I pulled out, I noticed that the following piece was on the ground. There was no visible damage to the car, but I am not sure if I hit something underneath the car. I am not 100% sure that this piece came from my car. It says it is' "Made in Germany" and it has a bunch of numbers.
Can anybody shed any light on this? I am scared to drive the car as it may be a crucial part.
Many thanks,
Nando
Old Sep 3, 2004 | 10:43 AM
NekoWoman's Avatar
NekoWoman
From: Fulltime RVer - R53 towed behind a vintage 1979 35' MCI MC-5C Saudi
Kind of looks like a jack point to me, but I'm definitely not the one to trust! Maybe that was already there & that's what made the noise...
What part of the car hit? Did you go over the curb? Details?
Old Sep 3, 2004 | 10:45 AM
Johnna's Avatar
Johnna
Not to worry. That is the jacking block. Looks to me like you can just jab it back in place.
Old Sep 3, 2004 | 10:47 AM
no_affiliation's Avatar
no_affiliation
yup that's a jacking block
Old Sep 3, 2004 | 10:49 AM
Nando's Avatar
Nando
I am not sure if I went over the curb or not, it happened kinda quickly. The piece that looks like it clips unto something was sheared off. I would probably have to get a new one. I am hoping this is not something to do with the suspension, and I will fly off the road when taking an exit ramp...
Old Sep 3, 2004 | 10:53 AM
Johnna's Avatar
Johnna
Who knows, you may very well fly off the road at the next exit ramp but rest assured, the jacking block won't have anything to do with it!
Old Sep 3, 2004 | 11:11 AM
asodestrom's Avatar
asodestrom
It looks like the part is OK from your pics. Push the pin, the thing that is in the missle that is split pack into the open part opf the block. Put the block back into the frame where it came from, and tap the extended pin in from the inside of the open part. The round head should be protruding a bit. That should cinch it down. If it fees solid, then you should be OK.
Old Sep 3, 2004 | 11:12 AM
Nando's Avatar
Nando
Thank you guys, I already called a dealer and they have them in stock. I will be picking it up right away. Part is only like $8.
Thanks a ton!!!
Nando
Old Sep 3, 2004 | 11:18 AM
MGCMAN's Avatar
MGCMAN
I don't think you need to buy a new one, just locate the hole it fell out of (two on each side) and pop it back in just like on the opposite side. It's extremely easy to do. Just don't run up any more curbs.
Old Sep 3, 2004 | 11:30 AM
NekoWoman's Avatar
NekoWoman
FYI... I would test that out before trusting it to jack the car... no need to lose a finger because something you didn't know cracked...
Old Sep 3, 2004 | 11:46 AM
MINIAK's Avatar
MINIAK
Yes, I agree, it is the jacking block and should pop back in. But if the dealer is going to get you a new one and install it for $8. I guess that is worth your piece of mind.
honderpilot
Oct 11, 2015 06:35 AM
martinb
Oct 7, 2015 05:00 PM
ToroPerro
Oct 1, 2015 12:54 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
sevin
Sep 24, 2015 05:00 AM
