R50/53 Random question: is it SAFE to leave a fuel rail disconnected?
Old Mar 17, 2016 | 08:32 PM
Kahnfucious's Avatar
Kahnfucious
Hey guys,
Doing some work on the car - got the injectors out (very corroded) - is it safe to leave a fuel rail and fuel line disconnected for a few days while j wait for some other parts? I disconnected the battery.
Old Mar 18, 2016 | 05:52 AM
slipmagt's Avatar
slipmagt
I dont see why it would be a problem as long as you arent dripping fuel, and you dont get any debris in the lines.
Old Mar 18, 2016 | 04:14 PM
Kahnfucious
Thanks follow up question - how far do the injectors seat info the intake manifold. This this just looks off??? I know the o ring does the sealing but should the injector sit further down?? The 2 13mm bolts are bolted down
Attached Thumbnails Random question: is it SAFE to leave a fuel rail disconnected?-image-2039445606.jpg
Old Mar 18, 2016 | 04:19 PM
slipmagt's Avatar
slipmagt
I'm on my phone so I can't be 100% but that looks like they are all the way in. When I changed mine I had them go in as far as they would physically go in.
Old Mar 18, 2016 | 04:26 PM
Kahnfucious
Thanks - yeah they can't move anymore forward because the fuel rail is holding them. I guess I didn't expect to have air space around the body. I know the O ring does the sealing..it just looks wrong somehow
Old Mar 18, 2016 | 04:28 PM
slipmagt's Avatar
slipmagt
If the orings are sealed and the rail is bolted I'd say your good. I was an idiot and forgot to snap the regulator back together before I tried to start it and dumped fuel all over my driveway. Luckly I had the forethought to roll the car out of the garage before I tried to start it.
Old Mar 18, 2016 | 04:43 PM
Kahnfucious
Ha - yeah that could have been tragic. I used a soft piece of wood against the rail to get the injectors seated after pushing on it and getting it as far as possible. Just started the car - all seems good...but no CEL or anything. Just took off intercooler again and don't really see any wetness...I broke one of the injector wire clips though...that sucks... :-(.....
Thank you for reassuring me slipmagt
Old Mar 18, 2016 | 04:47 PM
slipmagt's Avatar
slipmagt
I put a touch of oil on the orings and pushed them in by hand. I was using injectors from a Ford focus so I needed to trim the clips a bit to get them to fit nice.
Old Mar 18, 2016 | 05:04 PM
Kahnfucious
Yup - I took a tiny bit of oil and rubbed it on with my finger as well.
Updated: thanks again for the encouragement slipmagt...I took it out for a quick 1 mile jog. Everything felt pretty good, pulled the intercooler off again and didn't see any leaks or moistness. No doubt it's running rich on an S with 15% pulley. Hearing some rattling (paranoia) thinking it might be the timing chain tensioner...if it's not one thing it's another eh...I guess I'll order one up.
Alpha Motoring
Apr 9, 2016 11:06 AM
Car Care Products
Mar 17, 2016 03:35 PM
Mar 17, 2016 03:21 PM
Mar 17, 2016 03:08 PM
