I've converted Transmission from cvt to manual gearbox 6 speed .. But
Hello every body
Good evening Just now I finished convert my 2002 mini r50 none-s from Automatic cvt to 6 speeds manual gear box I replaced 1- both shafts 2- lever with cables 3- starter motor 4- brake pedal with clutch pedal * new clutch set * used 6 speed manual gear box * master cylinder * sleeve cylinder * clutch fluid pressure lines The mini now not start and there's faults about cvt I have some questions if there's somebody was do it before What I should do now ? 1- How can I change programs or coding ? 2- is there a relay need to change ? 3- what about wiring, is need to replace ? I have Autel maxsys pro scanner with programmer Tnx for all Regards Ali from BAHRAIN |
Your ecu is designed and coded for an automatic car. It's not reading the 6mt and is telling the car something is wrong.
For example in an auto you put it in park to start it and the comp reads that but a manual you compress the clutch and the comp reads that |
It has been done, but I don't have the details.
Way Motor Works has done a bunch. You'll need someone to reprogram the ECU, and I think there is at least one wiring harness to replace. |
Yes need to send us the computers and we can fix it. The car still thinks it's a CVT so it won't work
http://www.waymotorworks.com/cvt-to-...ogramming.html |
Just a stab in the dark, I'm sure there's some kind of neutral switch from the auto, could you not plug that in and trick the computer into thinking it's always in neutral? That should let it start and rev fine.
Originally Posted by X757XVeritas
(Post 4175802)
I will try to do something tomorrow Then I came back again to let you know Thanx for all I'm happy for replys |
As much as these cars are computer controlled I'm not positive it will work, but that's how I've done it on older vehicles before.
Good luck with that but I bet there's no way you will get it to work without getting your ecu programmed.
The switch to let the car start in park and neutral is basically the clutch switch in a manual. An auto car in neutral is basically a manual with the clutch pedal in as far as a computer is concerned.
Also way to be optimistic. I'm just trying to help him out till he can get it tuned right. |
Can't hurt to try that's for sure. Expensive to get that ecu programmed
(Post 4176194)
Also way to be optimistic. I'm just trying to help him out till he can get it tuned right. It's work now after I replaced Ecu & imblisaor with anthore for S But need program for abs traction The throttle not working normally I fill car not normal power I will try tomorrow to program it with autologic I hope it finish Thank you and all Will come back |
(Post 4176194)
Also way to be optimistic. I'm just trying to help him out till he can get it tuned right. Yes I did it The car starting now normally with the original former ECU Just i did something in wiring, jumper wire from EWS to ignition switch The EP still showing in cluster without any effect The engine working fine Driving & gear changing so fine See video 👇🏻 https://www.youtube.com/watch?v=ogHqO5vheUk every thing is done and fine without programming or coding Thanx for every one try to help me |
That's awesome, enjoy your new 6 speed!
Originally Posted by Shawnnn
(Post 4176553)
I figured it could be done without programming, that's awesome! Enjoy your new transmission!
(Post 4177497)
Great to hear you found a work-around fix!
The 6-speed should last just about forever. |
Originally Posted by slide mini
(Post 4176545)
Hello dears
Hell please
Hi can u help me with witch wire i need todo to make mine work thanks
(Post 4176545)
Hello dears
| All times are GMT -7. The time now is 12:10 AM. |
