R50/53 Mini monitoring
Old Feb 13, 2016 | 08:24 AM
Rubidon's Avatar
Rubidon
Mini monitoring
Hi guys, I have had mi '03 S with 85k on it for about six months now and want to start upgrading some performance stuff. I want to be able to monitor the car so I know if something is not working right. What is out there that I can do this with? I would like a stand alone unit but if not then an app and tablet might be the way to go, I am not sure.
Old Feb 13, 2016 | 11:23 AM
joshua stowe's Avatar
joshua stowe
I use an elm 327 Bluetooth adapter and the torque pro app. The elm 327 kinda sucks, it loses connection with the phone all the time. The torque app is great but mini doesn't have many pids so you can only really monitor fuel, engine codes, engine temp, intake temp, intake pressure, boost and vacuum, rpms and a few others
Old Feb 13, 2016 | 11:29 AM
joshua stowe
Old Feb 13, 2016 | 11:55 AM
MINIAC's Avatar
MINIAC
I currently have a Scangauge II in my 2002 MCS.
I'm considering swapping over to the Aeroforce Interceptor so I can mount it next to the tach with CravenSpeed mounts
Old Feb 13, 2016 | 12:09 PM
bavmotors's Avatar
bavmotors
Dashcommand via iPad2
Old Feb 13, 2016 | 12:31 PM
Rubidon's Avatar
Rubidon
I was going to buy a smaller tablet and leave it in the car and use the torque app but was worried about connectivity problems. I had an aeroforce in my bonneville ssei anf it was ok I just wanted something els with gauges or bar graphs. How does the dashcommand hook up?
Old Feb 13, 2016 | 12:39 PM
bavmotors's Avatar
bavmotors
wifi adapter, works well and stays connected
Old Feb 13, 2016 | 01:45 PM
X757XVeritas's Avatar
X757XVeritas
The main things I was worried to keep an eye on are boost, oil psi, and the battery voltage. You can't get oil psi through the obd port, and the readers that get boost have a lag. I've installed s boost gauge. Haven't installed my oil pressure or volt gauge yet. Been busy, and still gotta get that adapter so I don't have to drill into anything for oil pressure.
Old Feb 13, 2016 | 02:23 PM
sevin's Avatar
sevin
I'd recommend ECS's new scan tool, made specifically for BMW's and MINIs (and Bentley). I doubt it's very friendly for real-time monitoring if you want to be able to look at it as a gauge, but at $200 it's hard to beat. You can record sensor data and have it graphed I believe. It can tap into pretty much any module on the car, clear codes, program modules etc. Just take a look at it on the ECS page and check out the Q&A section as well.
Old Feb 15, 2016 | 08:59 AM
And Rolls Royce Not a real time driving ( moving )item as you have to be parked and not running but ignition on to communicate , but once on its on, real time.
Old Feb 24, 2016 | 05:53 PM
Rubidon's Avatar
Rubidon
I went with the cash command and a BT1, I will follow up in a few weeks .
Old Feb 25, 2016 | 05:45 PM
Rubidon's Avatar
Rubidon
My next question is how long does the obd2 port have power supplied to it after the keys are removed? Just don't want to run the battery down in the middle of winter.
Old Feb 25, 2016 | 05:46 PM
bavmotors's Avatar
bavmotors
never really got a straight answer on this, I think as long as you start your car everyday you should be fine though.
Rick-Anderson
Mar 13, 2016 09:58 AM
Naizur
Feb 12, 2016 09:13 PM
Naizur
Feb 11, 2016 11:20 PM
wilkrod
Feb 9, 2016 06:58 AM
switch
Feb 7, 2016 02:24 PM
