North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R50/R53 :: Hatch Talk (2002-2006) (https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006-8/)
-   -   R50/53 Harmonic Balance bolt won't budge! (https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/294961-harmonic-balance-bolt-wont-budge.html)
Smthkd Oct 26, 2015 04:38 PM
Hi guys, I'm trying to get the harmonic balancer bolt off but it won't break. I don't have a impact gun. I have put the car in 6th gear and had someone press break at same time but the darn thing won't break! Any suggestions?
BernieCoop Oct 26, 2015 04:45 PM
Get an impact gun... Electric ones work well. Really the only way to get it off. Just did the job myself. Got a Craftsman one and did the job!
bavmotors Oct 26, 2015 05:04 PM
Yea impact for sure don't really wanna heat it, make sure you use a plug in not a battery impact. They are like $50 at your local auto store, use it and return it if you want.
Smthkd Oct 26, 2015 05:16 PM
Thanks guys!
Kahnfucious Oct 26, 2015 06:26 PM
Originally Posted by Smthkd (Post 4138089)
Thanks guys!
Breaker bar worked fine for me...def step on the brake too.
Shawnnn Oct 27, 2015 05:17 AM
Blocking the tires works good too if no one is there to step on the brakes.
A good battery impact is amazingly strong and will easily get that bolt out
Helix13mini Oct 27, 2015 06:17 AM
You're going to have to 'shock' the bolt free with a gun.
Smthkd Oct 27, 2015 07:26 AM
Just bought a Impact wrench with 1400ft lb torque. Bolt "STILL" wont budge! This is frustrating! Starting to regret this R53 purchase!
Shawnnn Oct 27, 2015 07:39 AM
Did you get a get a good one? Companies just make up numbers a lot of times
The one I use is almost too strong. Breaks bolts off easy
Smthkd Oct 27, 2015 07:45 AM
Bought a Bostitch. Figured it was a good company but what kind do you use?
Helix13mini Oct 27, 2015 07:54 AM
Don't blame the car!
Buchner didn't blame the glove!:lol:
https://cimg7.ibsrv.net/gimg/www.nor...e85005fd29.jpg
Is the impact wrench electric or air. If it's air, what pressure are you running your compressor at?
Smthkd Oct 27, 2015 07:58 AM
:) Nice one. Its an electric tool. Any reason why it would be stuck? Its clearly the factory HB.
Shawnnn Oct 27, 2015 08:30 AM
Nice picture lol
Shop price hopefully shouldn't be too bad if you can't get it off.
bavmotors Oct 27, 2015 09:18 AM
Originally Posted by Shawnnn (Post 4138269)
Video Link: http://www.amazon.com/Milwaukee-Electric-Tool-2763-22-Impact/dp/B00GFUA7FC Nice picture lol Shop price hopefully shouldn't be too bad if you can't get it off.
I've only got the 1/4" m18. :(
Shawnnn Oct 27, 2015 09:23 AM
I don't actually own it. My two good friends both bought one :)
Hard to justify spending that much for something I would only use maybe once a year. Been very handy since I bought my mini though lol
Smthkd Oct 27, 2015 10:36 AM
Ok guys which direction loosen this bolt. Is it the old righty tighty lefty losey? Or is this a left tight, right loose?
Helix13mini Oct 27, 2015 10:41 AM
It's a standard thread bolt but it does have some locktite from the factory. You'll just have to get medieval on that sumbitch. Many electric impacts won't have the torque that a good air impact does with good pressure.
Kahnfucious Oct 27, 2015 10:52 AM
Yup - my Ryobi which claims like 300 lb ft couldn't get this to go - do you have a breaker bar? A long one?
Smthkd Oct 27, 2015 11:25 AM
Ok put the car back together and went to start it so I can go to a mechanic, now the car won't start. All lights com on but it won't turn over. Just get a check engine light and EML light! Now WTH!
Smthkd Oct 27, 2015 02:31 PM
So I took my car to a repair shop and after a few hits with the airgun....Success......the bolt came loose. You should see all the locktight Mini had on that bolt. Anyway....get the car home start using the pulley puller then. Disaster Strikes! SMH. One of the three bolt holes are stripped out. The previous owner must have done this. No prob. I'll just retap it. So get all bolts going the again...Disaster! On of the three screws break off and no it's stuck in the hole. So now I have to try and get the broken pieces out. Seriously I can't wait to get this job done!
Kahnfucious Oct 27, 2015 03:13 PM
Sorry man - that definitely sucks - I bought a die and tap for my car too - when I was replacing the valve cover gasket I stripped out one of the bolt holes for the "arms" that go over the intercooler. Almost there - use the right tool to back the bolt out - ridiculous that the screw broke off...they should be hardened.
bavmotors Oct 27, 2015 03:30 PM
My bolts kept breaker so I used a three jaw puller to get mine off, it was a hassle.
Kahnfucious Oct 27, 2015 03:35 PM
Interesting --- at least the pulley isn't on there very tight. Once you get it started it will come fairly easily. Use a torque wrench when you put the new bolt on - i suspect they used an impact wrench and over torqued it when they did the replacement last time. Just curious - you were doing this job because it failed? Or preventative...sounds like the car is still drive able
Also - probably shouldn't drive with a half snapped bolt in there - prob doesn't weigh much but at 4,000 RPMs I bet it be pretty imbalanced
Smthkd Oct 27, 2015 04:07 PM
Yeah it sucks but this happens so I gotta deal with it. Kahnfucious I had to replace it because it failed. I can tell it has separated into two pieces.
Eric_Rowland Oct 28, 2015 03:13 AM
Did this for a friend of mine and was nervous as hell after seeing Randy Webb have an issue at AMVIV, but fortunately it came off like butta.
Feeling your pain!
