R50/53 electrical problem
Old Oct 24, 2015 | 06:22 PM
mini beamer's Avatar
mini beamer
electrical problem
hello i hope someone can give me some advice have 03 r53 no warning lights speedo or tack power to all fuses and relays seen ok and the car also will not start thanks
Old Oct 26, 2015 | 02:07 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Hello. The first place to look for trouble in your starting system is your battery. The battery is perhaps the most important electrical component on the car, and due to its design and nature, is perhaps one of the most troublesome. Before doing anything drastic like replacing your starter or looking at your fuel injection ECU, you should make sure that your battery is in good condition. We have some good info here to help you with testing your battery.
888.280.7799 | 6am - 5pm PST
Old Oct 27, 2015 | 10:30 AM
1. Check the battery voltage first and have it load tested
2. Also check the terminals and ground points
https://www.northamericanmotoring.co...dding-wth.html
12429805422
skmboardchik4lyf
Feb 28, 2016 11:28 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
chicohuahua
Oct 1, 2015 10:33 AM
patsum
Sep 14, 2015 07:15 PM
shahriar35
Sep 12, 2015 08:31 PM
