R50/53 R53 m/c/s Oil Service Reset - No-Go...
Old Aug 19, 2015 | 08:09 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Just changed the oil on my '04 R53 m/c/s, and tried to perform the oil service reset to no avail. The last time I changed the oil 7500 miles ago, it worked like a charm - resetting to 15,500, but this time, no matter which of the methods I try, it won't happen...
Thoughts?
Old Aug 21, 2015 | 07:56 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I guess I'm the only one who's ever had this happen.
Maybe an ECU reset is the answer? I'm curious on the ECU reset -- Does disconnecting the battery result in the exact same circumstance as would the odometer menu + key executed ECU reset?
Old Aug 21, 2015 | 08:00 AM
Khai's Avatar
Khai
[QUOTE=AoxoMoxoA;4115451]I guess I'm the only one who's ever had this happen.
Maybe an ECU reset is the answer? I'm curious on the ECU reset -- Does disconnecting the battery result in the exact same circumstance as would the odometer menu + key executed ECU reset?[/QUOTE
Disconnecting the battery doesn't have the same effect. I disconnect mine all the time, when you do it through the odometer menu, the ecu has to re-learn the idle and stuff.
Old Aug 21, 2015 | 08:23 AM
Helix13mini's Avatar
Helix13mini
Keep fiddling with it. Sometimes I have to monkey about with the protocol to make it work.
Old Aug 21, 2015 | 09:15 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
May just need to keep trying. If you need help we do have directions for the reset in our oil change DIY here. See if it may help a bit.
888.280.7799 | 6am - 5pm PST
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
minicoclub
Nov 11, 2015 07:25 AM
Emnotek
Aug 13, 2015 05:47 PM
