R50/53 Fog Light Help!
Old Aug 2, 2015 | 02:03 PM
Alkaidovich's Avatar
Alkaidovich
Fog Light Help!
2005 Cooper S - No xenons and no fog lights
(I don't know what the build date is unfortunately)
Want: fog lights... Right now there are just plastic covers where the fogs would normally be. Also, the toggle bank has 2 empty slots for switches.
I've found very little info on how to do this, other than:
Buy set of fog lights, wire it to the harness, buy new toggle bank with switches for fogs, and have the BCM programmed (whatever that means )
I am in no way familiar or good with any kind of wiring, except basic stuff (mainly plug n play)
Do I have any other options, or I guess bigger question is - What ARE my options? Seems like this is going to be $$$ just to get some damm fog lights on my car lol but I am crossing my fingers and hope someone can help or point me in the right direction... Thanks!
Old Aug 2, 2015 | 02:46 PM
Capt_bj's Avatar
Capt_bj
buy some after market fogs and hang them
it will cost a fraction of what factory fogs would cost
you could do this for $100
to retrofit a full factory fog kit would probably cost you a grand today ...
Old Aug 2, 2015 | 02:52 PM
Alkaidovich
Right, i figured this... I was looking at the projector ones others have used... but how would I go about wiring these and a switch?
Old Aug 2, 2015 | 03:02 PM
rkw's Avatar
rkw
I wouldn't call that "very little info". You've found exactly what you have to do if you want OEM factory fog lights. I installed this myself on my car and it's a lot of work. Programming means after installing everything, take the car to the dealer and tell them to activate the fog light on the computer.
Just to be clear... you want actual "fog lights" down low for foggy conditions, and not auxiliary driving lights?
Old Aug 2, 2015 | 03:09 PM
Alkaidovich
Yes correct... not driving/rally lights. Actual fog lights that go down into those holes below the parking lights.
Well, looks like Ill have to see what the work is like to go with aftermarket and get a switch rather than getting factory fit fog lights. Anyone know if its any different ie. easier or harder going aftermarket? I know going aftermarket i run the risk of it not working properly or the longevity of it.
Old Aug 2, 2015 | 03:40 PM
rkw's Avatar
rkw
You can purchase the OEM fog light fixtures, which will fit correctly ($67 each, http://www.ecstuning.com/ES173915/). Then do custom wiring and switch.
Old Aug 2, 2015 | 03:44 PM
Capt_bj's Avatar
Capt_bj
what's your target?
Do you want lights in the OE holes
AND / OR
controlled by a toggle in the factory bank?????
IF so, this is gonna cost you both time and money
If you want to DIY you can have nice fogs for $100 . . . .
Old Aug 2, 2015 | 03:54 PM
rkw's Avatar
rkw
The OEM retrofit kit is only $139 (http://www.ecstuning.com/Mini-2005-C...B16A/ES173352/). You should be able to find a toggle panel on eBay for a reasonable price. That would leave cost of installation and programming. Installation would take about half day for someone familiar with working on an R53.
Old Aug 3, 2015 | 12:58 PM
+1 with what rkw said.
Old Aug 3, 2015 | 01:28 PM
Capt_bj's Avatar
Capt_bj
wiring those (or any other) lights to a simple switch is a piece of cake
here's the simplest diagram I can find
(the BOX with the numbers is a standard relay for adding a set of lights ... the numbers APPEAR on the relay as labels for the terminals . . .)
these parts can be found at any auto parts store and should run around $30. Soldering skills are helpful; or a crimping tool and some crimp type connectors. I use heat shrink on all connections to seal out water as well. Wiring this usually takes about an hour if you know what you are doing . . . takes longer to decide where to put the switch (which can be a simple toggle, or a rocker and even LIT if you want to get fancy) There are KITS that have the parts as well, all bundled up, but you PAY for the convenience. Google AUXILIARY LIGHT WIRING KIT
PM me if you want more help, or buy the lights and bring the car over. I'll install 'em if you buy lunch (and pay for the parts) .... kinda long drive tho .... would have been less if I still lived in Novato
(getting those OE lights into the holes on a GEN1 is not a small task . . you do not have access without some disassembly as I recall)
there ARE ways to mount aftermarket fogs low so as to be truly effective as fogs ..... some say, much MORE effective than the factory fogs .... a matter of opinion tho
Old Aug 3, 2015 | 08:07 PM
Alkaidovich
Thank you guys all for the replies, I guess I'll do a little more research and just decide on how to go about this. Capt_bj - I will be pm'n you to get more info and see how local you are... Like I mentioned, I am clueless when it comes to wiring so Id rather have someone who knows what they're doing, do it for a price I am willing to pay. Thanks again everyone!
Old Aug 4, 2015 | 06:30 PM
Alkaidovich
Quick update - Went to my local audio guys down the street where my friend works, and they're going to wire it up for me.
Just have to attach the lights and bring it in since they will be installing a new radio/audio equipment on my car (they have wiring, switches, etc.)
Will update this once its done... Going to order the kit from ECS right now.
Old Aug 5, 2015 | 04:53 AM
Awesome, thanks
Old Aug 13, 2015 | 07:03 AM
Alkaidovich
So quick update, ordered the Projector Fogs and apparently theres a Typhoon in Taiwan
Long story short, I get my money back and back to square one... So to confirm, if I end up doing custom wiring and switch, I need just the fog lights themselves and some bulbs, Retrofit Kit not needed?
Old Aug 13, 2015 | 07:11 AM
Fog lights themselves: w/ bulbs
http://www.ecstuning.com/News/MINI_R50_R53_Depo_Fog_Light_Kit_S_JCW_John_Cooper_ Works_Split_2002_2003_2004_2005_2006/
Old Aug 13, 2015 | 07:17 AM
Alkaidovich
Welp, looks like ECS will be taking my money again
Ill order up a set this afternoon/evening then...Thanks as always
Old Aug 13, 2015 | 07:52 AM
Welcome.
Old Aug 13, 2015 | 10:07 AM
Capt_bj's Avatar
Capt_bj
without the wiring harness it may be slightly more complicated to figure out the wiring as the lights probably are 'expecting' some funky connector. But in the end all they need is 12v and a ground . . .
But I recall you have help with the wiring so this should not pose a significant issue . . .
Old Aug 13, 2015 | 10:56 PM
Alkaidovich
I do have help... audio place said just come in when I get the lights and they've got all the wiring and switches to get it installed. They've done a few custom stuff for my past cars, so I don't see this as a problem to them but we'll see how it turns out.
Looking at the ECS kit it doesn't come with a wiring harness anyways...?
Old Aug 13, 2015 | 11:36 PM
Sp4rtan's Avatar
Sp4rtan
Retrofit instructions
In case anyone is wondering what is involved in installing the retrofit kit, these cover it pretty well. Not a small job!
File Type: pdf
Old Aug 14, 2015 | 04:57 AM
Capt_bj's Avatar
Capt_bj
the second number they gave you is just the lights fixture and bulb from the description
Old Aug 14, 2015 | 05:30 AM
Yep, just the set of light housings and the bulbs. The full kit with install wiring is linked above.
I posted only the set as you were going to use some aftermarket wiring.
Old Aug 14, 2015 | 07:57 AM
Alkaidovich
Honestly doesn't seem too involved or intense to me... its the cost for it all is the problem. Because the Kit itself is $140, a new toggle bank is another $120 or so... and who knows how much MINI will charge to code it.
Rather just get the OEM housing and do custom wiring starting to second guess doing fog lights after all
Old Aug 14, 2015 | 07:59 AM
Alkaidovich
so then does the retrofit kit actually come with the wiring harness? Did I miss it in the description...
EDIT: Did see the wiring harness... would I be better off just ordering the kit and then doing custom wiring from harness to switch? Or just housing with bulbs and let the shop deal with the rest
Old Aug 14, 2015 | 09:29 AM
Capt_bj's Avatar
Capt_bj
might be a question you want to ask the person that's going to do the work
all the harness really gives you is the fancy plug that mates to the socket on the light. Getting around this is not rocket science but IF you HAVE the plug with wires attached ... all you need to do is cut the plug off the harness and splice to the wire ends ....
I think I mentioned in a PM, that IF you were doing this on your own many parts of the OE kit could be used even if wiring up something yourself .... wire is wire ... an inline fuse pretty standard and there's a good chance even the relay is nothing special and would work on a DIY wiring solution.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
