R50/53 electric fan
Old Jul 17, 2015 | 01:01 PM
bneer's Avatar
bneer
electric fan
I've had a 2004 R53 since new. This is the first summer that the fan runs after the engine shuts off. Have never seen any change on temp. gauge, same temp. as usual. Is something about to fail. Just replaced plastic coolant tank with metal because it was leaking, second one. The plastic one lost enough to make me think that maybe the reason the fan was running. That doesn't seem to be the case as today under normal driving with the temp. gauge just under half the fan was running again after shut off. About 5 min. or so. Any thoughts, Thanks.
Old Jul 17, 2015 | 01:20 PM
ZippyNH's Avatar
ZippyNH
When the tank failed, its possible the system went low on coolant, and a bit of air got into the system...
Simple and free thing to do is bleed the system...see if it changes. Remember, there us TWO bleed valves... One by the top of the radiator. The other by the thermostat.
Old Jul 17, 2015 | 01:29 PM
bneer's Avatar
bneer
Thank you very much. I will do this.
Old Jul 17, 2015 | 03:34 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
This tech article here may be helpful when you go to bleed the system. It starts at the 9th paragraph from the bottom.
888.280.7799 | 6am - 5pm PST
USNAE2
16
Jun 17, 2022 07:17 AM
monkiboy
Oct 16, 2015 09:58 AM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
