R50/53 A/C Clutch Fell Off!
Old Jun 14, 2015 | 10:14 AM
chrismiller's Avatar
chrismiller
Today I discovered that my A/C outer clutch disc has fallen off and is laying on the road somewhere I assume. Compressor is 2 years old and out of warranty so no luck there. Has anyone ever had this happen and were you able to find a replacement disc? An online search turns up pretty much nil.
Old Jun 14, 2015 | 07:14 PM
David.R53's Avatar
David.R53
Check eBay. Someone posted recently they found the clutch assembly there.
Good luck...
Old Jun 15, 2015 | 04:31 AM
JABowders's Avatar
JABowders
Veteran: Army
Was it an BMW/MINI part or an Aftermarket other than OEM Compressor?
Motor on!
Old Jun 15, 2015 | 05:48 AM
chrismiller
It's a 4 seasons. New not a rebuild.
Old Jun 15, 2015 | 05:54 AM
chrismiller
The whole a/c clutch assembly is on Ebay for $161. I can buy a rebuilt compressor with a new clutch for less. All I need is the outer disc and screw. I am just having a hard time swallowing buying another compressor to replace one little part and its screw.
Old Jun 15, 2015 | 07:22 AM
David.R53's Avatar
David.R53
Found the DIY - it gives the Delphi part number ( you should confirm it fits your year). Delphi 01650060/0
https://www.northamericanmotoring.com/forums/how-to/233108-heating-and-air-conditioning-replacing-the-a-c-compressor-clutch-coil.html
But, it looks like you would be better off buying a used compressor and switching the clutch over.
Remember there is a pretty big time/expense associated with recovering the refrigerant and refilling if you remove the compressor.
Old Jun 15, 2015 | 08:17 AM
chrismiller
Sound advice. I think that's what I'll do.
patsum
26
May 29, 2021 06:29 PM
Khai
Feb 10, 2016 07:43 PM
unxpectederror
Oct 22, 2015 12:16 PM
Quixotic1
Sep 11, 2015 11:15 AM
