Thanks so much for the replies everyone! After doing more research last night, I decided to pick up some new vacuum tubing at the store & double check everything when I got home. Well, the short bit of tubing that plugs onto the BPV was rock hard and came off with the slightest push, so I'm sure that was contributing. The second culprit I found was inside my JCW intake's airbox. The small diameter tube that is T'd off of the BPV line had come disconnected inside the air box. I re-connected that and replaced the two shorter lengths of vacuum hose after the T (couldn't get to the line below to replace it as well but it seemed softer & more pliable than the two I replaced).
So, I reset the ECU & took it out for a spirited test drive. MUCH better!! Smoother off the line & I could hear the SC whine! However, after driving for a good 20 minutes, I felt that the car was starting to get a bit sluggish again. Not nearly as much as before, yet not as zippy as it was right after the ECU reset.
Quote:
Originally Posted by Gafer
(Post 4068596)
Any lights on the dash? Temp okay? Was it powerless before you did the supercharger service or did it start afterwards?
No lights on the dash (except for the stupid airbag light from the pass. seat sensor).
Quote:
Originally Posted by JABowders
(Post 4068601)
If the Tensioner is going bad it will allow the drive belt to slip and under power it will not be allowed to produce the power you are use to...
Motor on!
Okay, I'm glad you mention this. I also noticed that the new Goodyear Gatorback belt I recently installed has stretched beyond where it is supposed to be over the span of the past couple weeks. The first hole on the tensioner is no longer visible. I'm just running a stock pulley & ordered belt number 4060547. Is this belt known to be just barely too long or something? Would a failing tensioner cause this somehow?
Quote:
Originally Posted by IQRaceworks
(Post 4068841)
One easy way to tell is to buy a boost gauge....see how much boost your SC is actually making. If it's low, you know you either have a leak, have a bad BP valve, or have a bad supercharger. A boost gauge is cheaper than guessing and spending a bunch of money on something that isn't broken :thumbsup:
I would LOVE to get a boost gauge! If there's one thing that drives me nuts about this car, it's the lack of water temp and boost gauge. So ridiculous. One reason I haven't gone this route just yet is because all of the mounts seem to be designed to mount behind the single tach configuration, rather than the tach / speedo configuration that mine has since mine came with Nav. Does anyone have a recommendation for a good mount I could get for my setup? Looks like there would be -just- enough space to the left of the stock gauges, to the right would just be blocking that dash vent...
Quote:
Originally Posted by ZippyNH
(Post 4068869)
Check your SC boots...they might not be on right or you might have one split. They DO get hard with age...
Guess it is also possible something did not get assembled right...you used new gaskets when you put it together right?
Might want to rev it a bit, and use a smoke stick or something as a poor mans smoke test to check to see if you have a boost leak....
Yup, I used new S/C gaskets & have some Alta silicone intercooler boots being delivered this week, since I noticed the original driver's side boot was pretty full of shallow cracks, though not all the way through as far as I could tell.
Another thing I should tag onto the end here is that while I was looking at my belt tensioner situation, I noticed that the ticking I thought I'd solved by replacing the timing chain tensioner seems to still be there possibly louder? What's weird is that it really doesn't sound like it's coming from under the valve cover, it sounds like it's coming from just outside of it but I can't for the life of me figure it out. Has anyone else experienced this?
