R50/53 R53 cooper s idle troubles (re-visited)
Old Apr 17, 2014 | 10:35 AM
  #26
supersts's Avatar
supersts
I can vouch for that, changed the fuel filter with no change.. Will be changing my fuel pressure regulator, copper line, filter and v line tomorrow so will keep you posted on the results.
Old Apr 25, 2014 | 04:35 PM
  #27
supersts's Avatar
supersts
Changed the fuel regulator and copper fuel line, gave all that area a clean and triple checked connections.. Have had no idle issue since, even after a week of super spirited driving so will keep it going another week and update... Fingers crossed
Old Apr 25, 2014 | 09:00 PM
  #28
miles_miles7's Avatar
miles_miles7
before the change how often do you get hick ups?
Old Apr 26, 2014 | 03:46 AM
  #29
supersts's Avatar
supersts
Once or twice a week over about 200 miles a month
Old Apr 28, 2014 | 07:14 AM
  #30
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by Chili_head
I have the 200HP kit. No injectors, but not just the sound kit. I did not get the 380's nor the intake.
Just the head, upgraded (coated) S/C, pulley, exhaust, and 200HP tune.
In my particular case it was the 380's and JCW tune. I'm leaning more towards this being a software issue.
Old Apr 28, 2014 | 10:36 AM
  #31
supersts's Avatar
supersts
Still no issues since the new fuel assembly,
I am not so sure on this being a software issue at all... The car i have now never did this prior to summer last year and the ecu has not been touched. And the fact we get this issue across the board... Cooper s, jcw or home brew remaps... It points to a degrading part in my opinion,
Also anyone who smells fuel through your air vents should also change the fuel assembly.
Old Apr 28, 2014 | 10:43 AM
  #32
RockAZ's Avatar
RockAZ
Perhaps the software is not handling abrupt changes in vacuum pressure, an intermittant problem for sure.
Old Apr 28, 2014 | 11:15 AM
  #33
ZippyNH's Avatar
ZippyNH
Ouch....
If you EVER smelled gas in your car....you had Bigger issues....
Old Apr 28, 2014 | 12:23 PM
  #34
supersts's Avatar
supersts
No the issue was the fuel assembly, tiny bit of vapour escaping which was exacerbated by the heat/fan through the vents. Lots complain about the slight smell of fuel, some even think its normal, so as proven not always a serious problem, old cars stink of fuel it comes with age so lets not scaremonger people
Old Apr 13, 2023 | 02:11 AM
  #35
ysoserious's Avatar
ysoserious
Fuel rail
i realise it’s been a few years
I was wondering if you replaced the fuel rail or the fuel pipe running down the car to the fuel tank ?
thanks
Old Apr 13, 2023 | 02:11 PM
  #36
ysoserious's Avatar
ysoserious
did you change the line from the fuel pump to the pressure regulator and the regulator to resolve the issue ?
iggi
18
Feb 9, 2026 01:00 AM
mdutton11
14
Oct 26, 2015 01:47 PM
Aug 12, 2015 01:24 PM
MiniJess
Aug 10, 2015 09:51 PM
Lt. Dan
Aug 10, 2015 08:23 AM
