R50/53 Use this thing instead of a new engine mount
Looking at pics of other OEM engine mounts, and looking at mine, I'm thinking mine has lost its fluid, prob before I got the car?
Anyway, instead of $70 or so for a new one, can I "cheap out" and just get this deal (see link) http://www.ebay.com/itm/321225929294...84.m1438.l2649
I'm trying to reduce engine rocking enough to put my lower bracing back in, bc as of now the Cat is hitting the brace under full throttle (new exhaust system).
I already bought the powerflex gearbox mount, and have an engine damper installed on the block (old type), but just that damper is not cutting it right now.
Supplement= addition....not replacement....
It looks to be the knockoff of the same powerflex bushing parts...
Think it is for a 02-04...the rubber mount wears...shrinks...this goes over it to tighten it up...different part on the 2005+ cars...it is an oil filled balloon.... With a bolt through it...with no oil...nothing will tighten it up...just flopping around.
Probably because it's not worth it. Looking at it makes me think it doesn't make much difference. The bracket on the engine mount sits on the rectangular section, if that bushing isn't really tight between the bracket and the mount, the difference will be minimal. If you really want to test this bushing, I'd do it with a new mount. Putting it on a busted mount won't really solve the problem.
We have them here:
Upper Engine Mount Part # 22116778610
http://www.ecstuning.com/Search/SiteSearch/22116778610/
Here is the bottom torx bolt, that connect from the bottom part # 22116766753:
http://www.ecstuning.com/Search/SiteSearch/22116766753/
I'd love a VT one, but 300 smackers is just so much for an engine mount of all things :-P
I have a damper on the engine already, was considering adding an additional tsw to my setup... Dual dampers with a powerflex bushing on th gear box side, then maybe the superpro inserts for the lower mount.
That will just make more racket and will progressively make your existing mount worsen....That gizmo is made from hard poly....so something is gonna have to give and it will be your already compromised engine mount.
The OEM one lasted how long ? How many miles ? Just get a new one....my 2 cents.
Then get a TSW damper for the right side and a yellow Powerflex poly bushing insert for the trans mount on the drivers side....( give that insert about 600 miles to settle in before NVH disappears..)
The black gunk that comes out tends to corrode the bolt...and sometimes sieze it...so having a $1.50 bolt from mini is cheap insurance if you destroy it getting it out...on my last one...I needed the bolt.
I mean, seems like a lot of work to replace something that really is just a stick that wiggles with a base under it..?.
With the poly pad the engine mount is sitting on the pad mostly, seems like it should be just as good as a "new" mount. Should be fine with the other mount upgrades I'm doing... Besides, I'm still holding out for a used VT engine mount to come up!
Umm. No. I don't think it will be the same. I agree it fixes the height issue. It cannot fix the fact that the liquid - that ran out - was part of the vibration dampening, and helps limit motion of the mount. Changing the oem mount every 18 months or so is the price for the design constraints. Yeah my dealer was $10, but they are open till 7 pm, and on Saturdays until 3 pm for parts.
I paid $180 and had a shop install my last one....the fact they did it in about 15 minutes...even with the siezed bolt made me feel bad...but air-tools DO speed things up!!
After you've loosened the nut, Jack the engine above the bolt (With wood, under the sump) the other mounts can take it..
pull the old one, drop in the new one, shouldn't take more than 20 mins..
The torque is 70 Nano Webber's, i'm a music guy whadayawant? ")
Suggestion...
Save the old one...clean it out...and fill it with hotset urethane windshield adhesive... Sounds crazy...back in the pre TSW days...a few folks expermented with this...got the idea from Honda folks I think.....the TSW one is mostly a highly refined version of this idea...
There were a few threads on folks trying it....not sure how they turned out..I forget...but for some folks...you could experiment... And have some fun...have it ready for the next failure....
