R50/53 JCW Intake Bottom Piece
Old Dec 4, 2013 | 08:12 PM
sandplasma's Avatar
sandplasma
Hi Everyone,
I recently purchased a JCW Intake from a member here. I thought I was purchasing the whole thing but he only sent me the upper part. He said the bottom piece should be the same. I have been unable to find a bottom piece picture until now. Can someone verify that the bottom does indeed have a hole that the standard Cooper S doesn't? I started thinking about this after watching plenty a youtube video and noticing that their cars made a tad more noise (sc) than mine. Can this be why? I guess if it is the case, this can be a nice fix for those who don't like the noise but I want it!
Found this page where he shows a picture of the bottom... http://www.motoringfile.com/2006/02/...ld-air-intake/
Old Dec 5, 2013 | 09:53 AM
AndyPWR53's Avatar
AndyPWR53
The bottom portion of the air box is the shared between them. That picture is showing the difference in the firewall between the two intakes. The jcw intake has an extra hole there because it has a flap that is actuated above 4500rpm or so to get more fresh air. This should give you an idea.
http://www.madnessmotorworks.com/mad...-cowl-mod.aspx
Old Dec 5, 2013 | 09:56 AM
AndyPWR53's Avatar
AndyPWR53
part #1 in the diagram is the same between both intakes, assuming thats what you were referring to.
Old Dec 5, 2013 | 10:15 AM
sandplasma's Avatar
sandplasma
I see, thank you very much for clarifying. I guess my JCW Intake is pretty much acting as a regular intake (but with a cone filter) at this point. I will have to go ahead and drill a hole . Thanks for the info and pictures!
Old Dec 5, 2013 | 10:24 AM
Here is a picture of the JCW intake kit if that helps. Has the different partition then the stock one.
http://www.ecstuning.com/Search/SiteSearch/13720391513/
Thanks and good luck.
Old May 21, 2022 | 02:13 AM
Rays53's Avatar
Rays53
Resurrection
Hi,
Sorry for dragging up this old thread from the dead. Just wondering how you went with this. Did the JCW top airbox fit the stock R53 bottom airbox?
I need to replace my lower airbox (the top JCW cover is ok still), but ECS specifically state "Not for John Cooper Works kit"
https://www.ecstuning.com/b-genuine-...m/13721491741/
Old May 23, 2022 | 07:13 AM
Updated that I see it the same and updated the site on that bottom piece only.
hoonpv
May 29, 2008 08:03 PM
Chili R
Jul 1, 2007 04:20 PM
amg6975
Oct 9, 2006 08:38 PM
supersand
Apr 12, 2005 07:37 PM
LombardStreet
Feb 10, 2005 08:47 PM
