R50/53 Anyone change to synthetic tranny fluid?
Old May 21, 2004 | 07:17 PM
speltzer's Avatar
speltzer
Considering changing my 6-speed Getrag tranny fluid to 75w90 synthetic. Debating between Red Line and Royal Purple. After pulling the front drivers side wheel, I can see both the drain and fill tranny plugs. I appears to be an easy job. If you have done this, does the shifting smoothness get better?
"Meets Warranty Requirements
Max-Gear® exceeds OEM warranty requirements for GL-5 automotive rear axle hypoid gear lubrication."
_________________
2004 MCS - PW/B w/Xenons
Old May 21, 2004 | 07:29 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I have discussed this with Eric Savage at Helix13.com and he told me he talked to a MINI mechanic that recommends to always use OEM MINI transmission fluid and not aftermarket fluid.
I think if my dealer found another fluid in there they would void the warranty for the transmission.
Talk to Eric more if you have questions.
Same applies to those who add a Quaife LSD- stick to stock fluids.
Old May 21, 2004 | 07:46 PM
early_apex
This is probably reason enough to stick with stock. However, I have had very good luck with redline in other cars.
Old May 21, 2004 | 08:21 PM
gowest's Avatar
gowest
The fluid that comes in the tranny is synthetic! It's my understanding it's made by Texaco and is a rather odd spec, as cars go, as not many use this oil. This was discussed on MINI2 some time ago. You can find at least some of this info there, on my post "Quaife install thread". It also cost in the $25 to $40 per Qt. range. When I got my Quaife I talked with Red Line and then used their oil. It's now 17 months later and with many autocrosses and pulling a tire trailer 1,000's of miles I, as expected, still have no problems.
A MINI dealer will always say to use OEM parts and fluids.
Old May 21, 2004 | 08:28 PM
speltzer's Avatar
speltzer
Interesting. I was led to believe it's regular dinosaur crude oil...non-synthetic
Old May 21, 2004 | 08:37 PM
asodestrom's Avatar
asodestrom
Has anyone heard a "good" reason not to use redline or other high quality synthetics? Of course MINI people will stick with the party line, especially at $25 per quart. I would like to know why OEM is the way to go.
Old May 22, 2004 | 05:47 AM
resmini's Avatar
resmini
I was told by a service tech at Roadshow that the transmission fluid on my 5-speed was not synthetic. Perhaps it's different on the 6-speed?
R.E.
Colt45Magnus
Jul 14, 2019 06:18 PM
cawwwtun
May 3, 2016 08:03 AM
yukinoinu
Sep 20, 2015 09:10 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
